Old 05-24-2004, 08:37 AM   #1
skijay
skijay is on a distinguished road
Default Question about throttle body service and tranny fluid service
I had the coolant changed, transmission fluid & filter changed and the throttle body cleaned (they called it fogging). What is fogging?
My sticky gas pedal is long gone now!
The service manager told me that the AT fluid was very dirty. The SL2 is a 1997 and the tranny was serviced back in 7/2001 with 23,000 miles. The car now has 41,000 miles on it and was just serviced. What would cause it to get "dirty"? Is it because of the low mileage between services or perhaps it was never changed back in 2001? Going from P to R to D is smoother now. No more clunks which I thought was because of the new motor mount (less than 4000 miles).
Add to skijay's Reputation
Rate the quality of this post and help skijay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skijay is offline
Old 05-24-2004, 11:08 AM   #2
germ
germ is on a distinguished road
germ's Avatar
2008 Astra XR
Default
Your sticky go pedal was cause by carbon build up in your throttle body. I've had the same problem with mine before, as the stuff really likes to build up in there. Basically all they did was shoot throttle body cleaner into it and cleaned all the carbon off. As for transmission fluid, it's kinda of like oil. Heat does break down over time and it needs to be replaced. If I'm not mistaken it should be changed once a year. Speaking of this post had reminded me that I need to be changing mine here pretty soon.
Add to germ's Reputation
Rate the quality of this post and help germ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
germ is offline
Old 05-24-2004, 11:32 AM   #3
amazinghl
Default Re: Question about throttle body service and tranny fluid service
If your dip stick isn't pushed in all the way, dust can get in.
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
power steering - how 2 service fluid 97sl2DOHCaut1.9 S-Series Tech 13 03-11-2009 03:50 PM
service light after egr, throttle cleaning. banditkaine S-Series Tech 7 03-21-2008 05:36 PM
2004 3.5 V6 - Tranny Fluid Service: Drain and Fill or BG Full Flush Service? silversaturnvue Vue General 19 03-13-2008 07:54 AM
Coolant Flush/Brake Flush/Throttle Body/Fuel Injection Service? swayz95 S-Series General 8 11-05-2007 11:30 AM
Dealer Throttle Body Service vs Aftermarket SC1_Oil_Burner S-Series General 20 06-26-2006 08:16 AM
