Old 05-13-2004, 08:48 AM   #1
LoveMySaturn
LoveMySaturn is on a distinguished road
LoveMySaturn's Avatar
Default Fuel injector? Fuel filter? Air filter?
All right, here we go again. I have a problem when under 3000 rpms. If i floor it just sitting, or while driving, it will sputter all the way up to 3k, then just go like it used to, with much more power, its a very noticable difference. Anyway, i was told that it was my valve cover gasket, so I replaced that. Same problem. Replaced ECTS and PCV at the same time as the valve cover (yesterday). Is this an injector problem? Fuel filter? I just put in new plugs a couple weeks ago. I'm thinking maybe clean out the egr, plug wires and maybe a new air filter. What should I check for to fix this problem? Thanks in advance.
Add to LoveMySaturn's Reputation
Rate the quality of this post and help LoveMySaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LoveMySaturn is offline
Old 05-13-2004, 09:33 AM   #2
LoveMySaturn
Default
By the way, it does throw a SES light, but it flashes for about 15 seconds or so, then just shuts off. Hope this helps. I think it has to be on constantly for autozone to check it. not sure.
Old 05-13-2004, 09:43 AM   #3
bhall10
bhall10 is on a distinguished road
Default
Could be fuel delivery. Could be the EGR, and cleaning it out never hurts. Got a voltmeter? Could also be the MAP or O2 sensors. Valve cover gasket? I don't see how unless maybe wires are all gooped up with oil.
Add to bhall10's Reputation
Rate the quality of this post and help bhall10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bhall10 is offline
Old 05-13-2004, 09:48 AM   #4
LoveMySaturn
Default
What would I do with a voltmeter? My dad probably has one, he has a garage full of tools..
Old 05-13-2004, 09:59 AM   #5
bhall10
Default
You can check the voltage signals your sensors are sending the PCM(computer). Unfortunately, I'm not the one to ask how to do that. But I'm sure somebody here knows how.
bhall10 is offline
Old 05-13-2004, 11:05 AM   #6
saturntech-6
saturntech-6 is on a distinguished road
Default
Based on what you've written, the most likely suspect is your plug wires. On the 's' cars they only last about 50'ooo miles before they start cross-firing to each other. We rarely ever have any injector problems, and the egr won't make it miss onhard acceleration. Good luck, let me know.
Add to saturntech-6's Reputation
Rate the quality of this post and help saturntech-6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturntech-6 is offline
Old 05-13-2004, 11:19 AM   #7
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Before you replace the wires, try cleaning the coil pack connectors. Also if you haven't done a fuel filter, you probably should.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 05-13-2004, 12:28 PM   #8
LoveMySaturn
Default
the coilpack is just on the other end of the plug wires right? if so, I already checked them, and there was no corrosion on them, but i cleaned them off with a rag anyway. i bought a egr valve gasket today, so I'll clean it off and see what happens. then i'll probably do the plug wires. How hard is a fuel filter change? It looks buried...
Old 05-13-2004, 01:47 PM   #9
wolfman
wolfman's Avatar
Default
A FLASHING SES light means basically ONLY one thing, a MISFIRE. Your either have a plugwire, coilpack or spark plug problem. It is also possible on far more rare instances for a very lean (stuck) injector to cause a misfire. Please tell me you installed CONVENTIONAL, NON PLATINUM PLUGS properly gapped to .040.
Add to wolfman's Reputation
wolfman is offline
Old 05-13-2004, 10:14 PM   #10
Default
A flashing SES light means that there is a catalyst damaging problem happening. The cause is normally a misfire caused by whatever. I would not drive the car very much/at all until you have the problem solved. If you had a leaking VC gasket did it leak into the plug wells? If so did you get carbon tracking on the plugs and wires?
Add to ssicarman's Reputation
ssicarman is offline
Old 05-13-2004, 11:50 PM   #11
LoveMySaturn
Default
i put in what was in the car before, AC Delco plugs, gapped at .040. I changed the fuel filter, all kinds of black nasty gas in it, probably never changed. Still have the problem. Next step should be wires? They are bosch, so they have been changed in the past. The coilpacks look clean. Think they could still be the problem? And I have to drive this car. It is my only car...
Old 05-13-2004, 11:56 PM   #12
LoveMySaturn
Default
One thing I've been forgetting...It smells like gas out of the exhaust pipe. Any thoughts?
Old 05-14-2004, 07:15 PM   #13
LoveMySaturn
Default
So should I go out and buy some plug wires? Are the $25 ones from autozone ok?
Old 05-14-2004, 09:14 PM   #14
Default
If you are smelling gas out of the tail pipe the the car is running way to rich. You said that you replaced the ECT sensor. Did you inspect the connector to see it there was any corrosion in it. If there is then the PCM could still be getting the wrong temp signal.
get the codes from the PCM. They will be stored.
1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires) onixwj S-Series Tech 12 12-11-2009 08:07 PM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 06:29 AM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 09:43 PM
Questions-Air Filter, Fuel Additive, Steering LuzianaAuraLuvr Aura General 12 04-10-2008 09:51 PM
1998 Fuel Filter - (Fuel line retainers) Jeffsimpson S-Series Tech 3 01-30-2008 08:42 PM
