Old 05-09-2004, 08:32 PM   #1
Phatbass
Phatbass is on a distinguished road
Wrench Replacing the PCV Valve
I know this is going to sound like a dumb question but here it goes:
I have been reading a ton on this forum over the last few weeks, and I have been noting the common matinence procedures that are recomended like the ects, changing oil, the pcv valve, change the thermostat, plugs and wires, tranny fluid, the fuel filter, and the egr valve. After reading all these things I have read how tos for all the parts except a pcv valve. I was wondering if someone could post where it is located and how to go about changing one out. Please educate a newbie. Thanks.
Add to Phatbass's Reputation
Rate the quality of this post and help Phatbass reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phatbass is offline
Old 05-10-2004, 12:11 AM   #2
amazinghl
Default
It's in your valve cover. Pull out the hose and pull the metal tube you see.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 05-10-2004, 12:51 PM   #3
jasonpopnc
jasonpopnc is on a distinguished road
Default
How to Change PCV Valve.
Tools/Parts Needed:
2 Hands (Preferably with opposable thumbs)
Carb Cleaner
New PCV Valve
Valve Hose (new if hose is deteriorated)
The PVC valve is located in the valve cover (top "cover" of the engine, near the oil filler cap) On DOHCs, it is immediatly to the right. On SOHCs, it a few inches to the left.The PVC valve is held to the valve cover with a rubber grommet type seat.
1. Remove the hose that connectes the throttle body unit to the PVC valve.
2. Using your hands, remove the PVC valve from the rubber seat. Wiggle it back and forth, then pull it straight out.
3. You can either clean this with carb cleaner, or simply replace it with a new one (<$5 at most auto stores)
4. Put the PVC valve back into the rubber seat and replace the hose.
Add to jasonpopnc's Reputation
Rate the quality of this post and help jasonpopnc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jasonpopnc is offline
Old 05-10-2004, 02:24 PM   #4
Phatbass
Default
wow thats easy, thanks
Phatbass is offline
Old 08-18-2004, 01:03 PM   #5
Razorbak
Razorbak's Avatar
Default
Don't use an aftermarket part to replace your PCV valve. Only use the OEM valve from Saturn. (Price is virtually the same, but the Saturn part works correctly with Saturn engines, while some aftermarket parts do not.)
Add to Razorbak's Reputation
Razorbak is offline
Old 08-18-2004, 10:18 PM   #6
Hiddenlites
Hiddenlites is on a distinguished road
Hiddenlites's Avatar
1993 SC2
Default
I picked up a PCV valve (AC-Delco) from my Saturn dealer last week for $3. And that is from a dealer that usually has a good markup on their parts.
1993 Saturn SC2 75k
2004 Chevy Silverado Z71
2008 Saturn VUE Redline 175k sold 7/8/16
2013 Honda Accord Coupe
2016 GMC Acadia
Add to Hiddenlites's Reputation
Rate the quality of this post and help Hiddenlites reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiddenlites is offline
Old 03-11-2005, 10:16 PM   #7
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
Default Re: Replacing the PCV Valve
I got my PCV valve from partsource for $3.00 CAD
Add to the_new_raceman's Reputation
Rate the quality of this post and help the_new_raceman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_new_raceman is offline
Old 07-06-2005, 11:46 PM   #8
2002SaturnMan
2002SaturnMan is on a distinguished road
2002 SL1
Tools/Parts Needed:
Carb Cleaner
New PCV Valve
Thank you for these work instructions. I'm going to do this on Saturday.
I purchased a Fram FV295 for $2.56 for my 2002 SL1 (SOHC) Saturn. Is this the right one???
I've read that some people can't get the PCV Valve to fit into the OEM hose???? I have 61,000 miles and this is the first time I've tried to do this myself. Saturn did the 30K maintenance for me.
Thanks!
Add to 2002SaturnMan's Reputation
Rate the quality of this post and help 2002SaturnMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2002SaturnMan is offline
PCV Grommet and PCV valve Spartus S-Series General 12 06-29-2009 11:07 PM
Replacing broke pcv valve vacuum hose zerostar S-Series Tech 9 05-31-2007 05:56 PM
Replacing a PCV valve with a thick hose edlee S-Series General 20 01-04-2006 12:01 AM
Does the L have a PCV Valve ricksLS1 L-Series General 2 10-28-2004 09:42 AM
PCV valve Aldiaz2331 S-Series Tech 2 10-14-2003 03:15 PM
