Old 04-30-2004, 05:50 PM   #1
KBM3
KBM3 is on a distinguished road
Default '92 SL2 help needed
My 1992 SL2, for lack of a better word, bucks or surges when going a steady 28 to 30 mph. It runs fine at other speeds and does not act at all weird when accelerating at any speed. The problem only occurs at the above speeds (so far) and is actually occuring intermittently. Does any one have any idea what may be going on?
Thanks.
Add to KBM3's Reputation
Rate the quality of this post and help KBM3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KBM3 is offline
Old 04-30-2004, 08:17 PM   #2
sattech
sattech is on a distinguished road
Default
Best guess would be that the EGR valve is coming on too early or too much. The best way to check this is to disconnect the EGR valve. The valve is the gold "UFO" looking valve at the back of the engine. Just disconnect the vacuum hose from the top of it. If the problem goes away The valve is bad.
good luck
~ If it worked before you messed with it, it must be something you did ~
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 04-30-2004, 08:48 PM   #3
wolfman
wolfman's Avatar
Default
What he ^ said. I would only add to plug the end of the removed hose with a golf tee or similiar item.
Add to wolfman's Reputation
wolfman is offline
Old 05-01-2004, 07:11 PM   #4
KBM3
Default
Well, you hit it right on the head. I unplugged the valve then plugged the hose with a nail and voila the bucking disappered!!
Thank you very much.
Now the question is, do i fix it or leave it unplugged??
KBM3 is offline
Old 05-01-2004, 08:57 PM   #5
sattech
Default
The EGR valve is an emissin item used to lower oxides of nitrogen in the exhaust stream. Without it you may not pass emissions in your state. Another reason for the valve is to lessen or eliminate predetonation (engine ping). Engine ping has been described by some as equivilant to someone taking a large hammer and slamming the top of the pistons.
sattech is offline
needed valvebody for 94 sl2 mrbusakidd S-Series Tech 1 07-16-2009 04:57 PM
Advice needed on selling 95 SL2... MrsK S-Series General 4 08-19-2006 08:25 AM
Sl2 Cluth advise needed kwk S-Series Tech 11 10-17-2005 01:27 PM
1996 SL2 - Opinions needed. phonic S-Series General 22 09-16-2005 09:08 PM
Troubleshooting help needed with 95 SL2 Epix12000 S-Series Tech 6 01-10-2005 08:33 AM
