Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 04-29-2004, 06:57 PM   #1
plumsl2
plumsl2 is on a distinguished road
Default Need wiring help
I just got a set of polk audio EXE crossovers today. I wasn't planning on putting crossovers in the satty, buuuut since I got em for free, I can't resist. First of all, does anyone know if polk audio stuff is any good? I've never worked with polk audio, so I really don't have any idea. Secondly.........how the hell do you wire these things up? All I know is that they are passive. There are connections for input positive and negative, woofer positive and negative and tweeter positive and negative. Any help/info you can give me is a great help. Thanks!
Add to plumsl2's Reputation
Rate the quality of this post and help plumsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plumsl2 is offline
Old 04-30-2004, 04:43 AM   #2
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
Default
Not sure if this helps but it sounds similar to mine. First off, decide where you want the tweeter to be, and where you want the crossovers to be. Make sure you have enough wire to run from each place. For those to work you probably need an amp. From the amp, run the wires from the front drivers side on the amp to the obvious front drivers side crossover. Those wires go into the input terminals on the crossover. Then depending on how you want to do it, you run the wires for the speakers to the crossover. The tweeters should be straight forward, just run the wires coming off of them to the corresponding terminals on the crossover. The only real trick is the woofer wires. My suggestion would be to look where your HU is connected to the factory wiring harness, and find the correct wires. If I remember correctly, the wires for the drivers side will be whlite/positive, white-black/negative. On the passenger side, it was gray/positive, gray-black/negative. You will probably need to crimp a wire to these, to attach to the crossover. In this case, the white to the positive on the crossover, the white-black to the negative. I found it helped to go ahead and hook up the amp and make sure the drivers side worked right before I started on the passenger side. Then youll have to do the same thing on the other side. Run the wires from the amp(front right), the tweeter, and then the woofer(gray, gray-black), all to the crossover. I was able to put the crossovers under the dash, behind the plastic panels, and it made wiring much easier. If you dont have an amp, just replace the wires coming from the head unit, with the ones I said to use for the amp. IE..where you disconnected them to use on the woofer input, just use those as the +/- input. LOL. If you get confused just let me know. Hope it helps, and good luck!!!!
'01 SC2 - sold
Add to Bigbadbert's Reputation
Rate the quality of this post and help Bigbadbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigbadbert is offline
help with wiring!!!! dsig18 Ion Tech 16 02-23-2009 09:28 PM
Wiring... dracar S-Series Tech 5 06-09-2007 10:30 PM
Wiring dracar S-Series Tech 9 12-30-2006 10:40 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
Need some wiring help Campainger Vue General 8 05-29-2003 02:56 AM
