Old 09-13-2000, 08:20 PM   #1
greenskeeper
greenskeeper is on a distinguished road
Default daytime running lights
Hello all,
I was wondering if anybody knew or attempted to put a switch on the daytime running lights so that they could be turned on and off as needed....or even how to disconnect them all together. My reason for this is when I go to work in the morning some days it is better to see with just the fog lights on.
Thanks
kaboz18@aol.com
Add to greenskeeper's Reputation
Rate the quality of this post and help greenskeeper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greenskeeper is offline
Old 09-13-2000, 08:53 PM   #2
Roger '97SL2
Roger '97SL2 will become famous soon enough
Default
If you turn on the Parking lights the running lights go off.
So... Turn on the parking lights and Turn on the fog lights.
This way others may be able to see your rear also.
Add to Roger '97SL2's Reputation
Rate the quality of this post and help Roger '97SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Roger '97SL2 is offline
Old 09-14-2000, 05:10 AM   #3
Three Rings
Three Rings is on a distinguished road
Default
Pulling the parking brake one click will turn off the daytime running lights and won't set the parking brake if it is adjusted correctly.
Add to Three Rings's Reputation
Rate the quality of this post and help Three Rings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Three Rings is offline
Old 09-14-2000, 09:12 AM   #4
wei_
wei_ is on a distinguished road
wei_'s Avatar
Default
Actually, the parking lights will not turn the DRLs off. I wouldn't recommend the brake lever approach as there is a possibility that you will overheat your brake system.
-Wei
Add to wei_'s Reputation
Rate the quality of this post and help wei_ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wei_ is offline
Old 09-14-2000, 12:06 PM   #5
white_base_LS
white_base_LS is on a distinguished road
Default
I don't like the DRLs, so I pulled the DRL relay (on an LS, it is within the underhood black box). This was okay (everything worked fine) except for the high beams. Only one high beam worked!
I will be trying to figure out the relay wiring so I can run a jumper wire for the high beam. That way I can have all the lights work the way I want them. I find the DRLs very annoying when I see them on other cars.
Add to white_base_LS's Reputation
Rate the quality of this post and help white_base_LS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
white_base_LS is offline
Old 09-14-2000, 02:29 PM   #6
greenskeeper
Default
I will try to find that relay for the DRL on my saturn (97SC2) and hope that both high beams will work. I agree....daytime running lights are annoying because in all reality they are high beams! At least saturns aren't like some cars where there's a computer which even determines when to turn on the regular driving lights!
Old 09-16-2000, 07:16 AM   #7
rosenjohn_sl2
rosenjohn_sl2 is on a distinguished road
rosenjohn_sl2's Avatar
2007 VUE Green Line
Default
You can order DRL overide units from Galls Inc. They sell to police and fire but most items do not require you to be a police officer or firefighter. The web site is www.galls.com
I couldn't fid the overide on thier web site but it is in the catalog and if memory serves runs between $40 and $60.
Maybe its just me but I have had more people pull out in front of me with the DRL than I ever did on my old 93 Eagle Vision with or without headlights on.
Add to rosenjohn_sl2's Reputation
Rate the quality of this post and help rosenjohn_sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rosenjohn_sl2 is offline
Old 09-16-2000, 08:15 AM   #8
GoKyu L300
GoKyu L300 is on a distinguished road
GoKyu L300's Avatar
Default
Do the DRL turn off if you turn on your normal nighttime driving lights (NDL)? Because if the DRLs are like high beams, I believe it's not allowed to have high beams on unless you're on a deserted stretch of road (hmm...reminds me of some B horror movies
I don't have my L-300 yet, just wondering, as I haven't owned a car with DRL before...
-Bryan
Add to GoKyu L300's Reputation
Rate the quality of this post and help GoKyu L300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GoKyu L300 is offline
Old 09-16-2000, 10:54 AM   #9
wei_
wei_'s Avatar
Default
Bryan, and others,
Yes, the DRL's are the same physical bulbs that are used for high beams. However, those bulbs are not high beam when in 'DRL-mode'. The bulbs operate on reduced power (30-50%) when operating as DRL's. When high beams are turned on, they use 100% of their power.
The best way to see this for yourself is to either place a mirror in front of your Saturn, or have someone switch between high's and DRL while you stand in front. I'd suggest wearing sunglasses first and not switching to normal nighttime lights in between. Going directly from DRL to high beams will give you a better understanding of how bright DRLs really are. At night, if you play with the 3 different light settings, you'll notice that the light intensities do differ in all three modes. (Yes, I've done this all due to idle curiosity).
Finally, my DRLs have been useful at night. During heavy snow storms, under very specific circumstances, the DRLs give better visibility. This is because there is enough light to light my way, but not too much light shining back off the snow.
Ultimately, have fun in your Saturns, no matter what you decide. <img src="http://www.saturnfans.com/cgi-bin/UltraBoard/Images/Happy.gif" border="0" align="middle">
-Wei
wei_ is offline
Old 09-16-2000, 05:53 PM   #10
greenskeeper
Default
well i attempted to remove the DRL relay and as expected the left high beam did not work once i tried to put on the high beams....it seems saturn figured people would attempt to remove the relay to disable the running lights and to discourage this they wired the high beams through the relay. Now does anybody out there know how to read a schematic? My haynes manual has wiring diagrams and if I could figure out which of the contacts on the relay carry the current for the left high beam then I could remove the relay, splice over the 2 contacts and in theory I would have both high beams and no running lights! I am not going to do any random splicing in case something would short so I am still trying to figure out the wiring.
Greenskeeper
Old 09-16-2000, 08:56 PM   #11
sattech
sattech is on a distinguished road
Default
One click on the E-brake is not a good idea. If the E-brake switch is grounded the DRL's will stay off the switch is on the e-brake lever under the center console. Do not try this on a 2k S or L car. Those cars chime when the E-brake is applied. On the earlier models the brake light would stay lit . I'm not suggesting you ground the wire, I'm just letting you know how that part of the ckt works
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 09-16-2000, 09:42 PM   #12
LDB_2001SC2_#54of99
LDB_2001SC2_#54of99 is on a distinguished road
Default daytime running lights, belts and airbags
How are the DRL's a problem? They run at a much lower light output than low beam headlights. The foglights on my SC2 put out more light than the DRL even. I have tested every combination of lights while parked about 50' behind my wife's truck just to get an idea of beam patterns, intensity, etc. I wish the DRL were like my old VW which was low beams at 95% power plus parking lights. I never turned the lights on unless I wanted high beams. The Saturn setup is nice however as you can always tell another Saturn driver from long distances. While you are modifying don't forget to hook your airbags and seatbelts to your DRL switch.
Add to LDB_2001SC2_#54of99's Reputation
Rate the quality of this post and help LDB_2001SC2_#54of99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LDB_2001SC2_#54of99 is offline
Old 09-18-2000, 11:47 AM   #13
Green_mtns_VT
Green_mtns_VT is on a distinguished road
Default
In My 98 SL2 I:
- Pulled the DRL Relay (A very standard automotive relay, I might add).
- cut a two inch piece of wire (stripped the ends)
- pushed the ends of the wire into the relay pin holes marked 30 and 87a.
- Done.
Tada -- Disconnected daytime running lights and no more bucked tooth look.
Add to Green_mtns_VT's Reputation
Rate the quality of this post and help Green_mtns_VT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Green_mtns_VT is offline
Old 09-18-2000, 06:01 PM   #14
tabo
tabo is on a distinguished road
Default
I guess you can blame us Canadians for those DRLs. Transport Canada did a bunch of research and found that vehicles with DRLs were far less likely to be in a collision. As a result, all cars in Canada have had DRLs for many years. I believe it started in '88 or '89.
To be honest with you, I have never found them to be a problem in any kind of weather. I also feel much better knowing that the people in front of me have a better chance of seeing me in their rear view mirrors.
The only exception to the general rule of de-powered high beams is Daimler-Chrysler, which has taken to using bright bulbs located in the parking lights instead.
Add to tabo's Reputation
Rate the quality of this post and help tabo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tabo is offline
daytime running lights cooleyblues S-Series Tech 4 02-10-2016 09:53 PM
Daytime Running Lights kodak_jack Vue Tech 5 10-03-2007 09:14 AM
Daytime Running Lights. Jinjo S-Series General 15 06-03-2006 12:46 PM
Daytime Running Lights. Jinjo S-Series General 4 04-30-2006 08:55 AM
Daytime Running Lights out. astoria29 S-Series General 15 05-19-2005 10:47 PM
