Old 03-18-2004, 12:24 PM   #1
Mike H
Mike H is on a distinguished road
Default Engine Cooling Fan and Temp Gauge
I just replaced the engine cooling fan in my '93 SL2. it wasn't kicking on at all, even when wired directly to the battery.
Testing it after installation, it would not kick in until the needle on the temp guage touched the red area near the "H." Is this normal?
Add to Mike H's Reputation
Rate the quality of this post and help Mike H reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike H is offline
Old 03-18-2004, 12:45 PM   #2
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Yes. If you would rather have it come on sooner, it is quite easy to make a manual fan switch to turn it on or off when you want to. Also, might be worth checking to see if your Coolant Temp Sensor is good. It should be the newer brass design.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
temp gauge goes to 3/4 for fan to turn on nwhamann S-Series Tech 20 07-23-2009 02:18 PM
Coolant temp sensor controls the cooling fan? Toadfish S-Series Tech 2 11-17-2007 12:48 PM
Cooling fan/temp gauge/etc... FixinAgin S-Series General 13 07-15-2005 07:26 PM
Coolant Temp Sensor - Fan or Gauge? petemcs Miscellaneous Tech 3 01-05-2004 10:37 AM
Engine cooling fan thread? SaturnDrive Mods and Performance 2 06-21-2002 04:26 AM
