Old 03-15-2004, 03:11 PM   #1
programmer12
programmer12 is on a distinguished road
Dizzy Service Engine Soon - P0171 & P0174 HELP?
Hello everyone, I appreciate your willingness to help me as I am wanting to get my hands dirty and fix my car myself.
I have an LS 3.0 liter 2000 - I have the SES light coming on and the guy at AUTOZONE read my 2 codes as:
P0171 System Too Lean Bank 1 and
P0174 System Too Lean Bank 2
What would this mean?
I have @45k miles on it and it runs good. Just the light is on, that's all. Gas cap is tight and retightened, so it isn't that.
Wondering about O2 sensors now. Upper or lower one? Or what is causing them to read too lean? Because they are reading too lean doesn't mean they are bad does it? It might not even be them at all. They may be indicative of something else that is making the reading too lean.
HELP, I know you all are experts on this and know what to tell me to try.
Thanks in advance.
Add to programmer12's Reputation
Rate the quality of this post and help programmer12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
programmer12 is offline
Old 03-15-2004, 03:19 PM   #2
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default
First, welcome to SaturnFans!
Second, try posting the same info on our tech section. They might be more familar with engine codes you mentioned over there.
Good luck!
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 03-15-2004, 08:10 PM   #3
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
2000 Saturn LS2 V6-181 3.0L DOHC VIN R SFI
Top - Vehicle
Powertrain Management
. Computers and Control Systems
. . Testing and Inspection
. . . Testing and Inspection Procedures
. . . . Trouble Code Diagnostic Charts
. . . . . P0171
Notes
P0171
A closed loop air/fuel metering system is used to provide the best combination of driveability, fuel economy, and emission control. In this system, short term fuel trim is accomplished by the ECM rapidly responding to the oxygen sensor readings. These changes finely tune engine fueling. Additionally, long term fuel trim is determined by trends in short term fuel trim, and serves as a coarse tuning mechanism for engine fueling. Fuel trim values near 0% are ideal. As the value increases, this indicates that the engine is in a lean state. Smaller values indicate a rich state of operation. The ECM in the vehicle stores fuel trim values for three different speed/load ranges: one at idle and another at medium speed/load, another at high speed/load. This code sets when the fuel trim is excessively high in any of the three speed/load ranges.
DTC PARAMETERS
This DTC will set if closed loop is active, and the following fuel trim limits lave been exceded:
Idle: 7.7%
Medium speed/load: 21%
High speed/load: 21%
DTC P0171 is a (type B) DTC
DIAGNOSTIC AIDS
The following are malfunctions that could cause a lean condition:
Vacuum leak
Fuel pressure low
Poor fuel quality/water in fuel
Exhaust leakage around manifold or front O2S sensor
Fuel injectors clogged.
IMPORTANT: If the front oxygen reading is greater than 1.2, and the rear HO2S is below 300 mV all the time, the O2 sensors are probably not at fault.
Copyright 2004 ALLDATA LLC
Terms of Use
Top - Vehicle
. . . . . P0174
Notes
P0174
DTC PARAMETERS
Idle: 7.7%
DTC P0174 is a (type B) DTC
DIAGNOSTIC AIDS
Vacuum leak
Fuel pressure low
Exhaust leakage around manifold or front 02S sensor
Terms of Use
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline
Old 03-16-2004, 10:06 AM   #4
sattech
sattech is on a distinguished road
Default
We usually see a contaminated MAF sensor with these codes. The only way to fix a contaminated sensor is to replace it. If you have Ma,/ Ca. emissions it may be covered 3yrs/ 50k miles
~ If it worked before you messed with it, it must be something you did ~
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 03-16-2004, 11:30 AM   #5
programmer12
Default
Thanks, I guess the MAF sensor has been contaminated. My first post says a 2000 LS2 so I guess I have to buy one. Any ideas where adn how much to pay?
Old 03-16-2004, 11:36 AM   #6
spork
spork is on a distinguished road
spork's Avatar
Default
I'd say before you try anything, throw in a bottle of Techron or some other injector cleaner. I had my car throw a code due to some bad gas. I put in a bottle of Techron and filled the tank with gasohol. No problems since. If the code doesn't go away, ask the guy at autozone to reset the code. If there is still a problem, the code will trigger again, and then you can take it in to Saturn for more expensive solutions.
"Don't blame me, I voted for Kodos"
Add to spork's Reputation
Rate the quality of this post and help spork reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spork is offline
Old 03-16-2004, 11:47 AM   #7
programmer12
Default
Thanks, I'll try the injector cleaner. I had the guy from autozone clear the code and boom five minutes later it went on again.
I'll get the injector cleaner.
Can the MAF be cleaned? It seems like a mechanical sensor. Wire heats up....
They must be able to thoroughly clean it at the factory when manufacturing the part, so couldn't I clean it also. With like a Qtip and alcohol.?
IS it worth a try. HOw do I keep it from getting dirty again? A dealer should reprogram my car to not heat up the maf after the engine is shut off so it won't attract oil to contaminate it.
Old 08-31-2004, 07:59 PM   #8
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
This is an older thread, but my car is now throwing the same codes. My SES has been going on/off with these codes.
Did the injector cleaner work? Or did you have to replace the sensor? Is MAF sensor replacement difficult?
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 08-31-2004, 09:40 PM   #9
spork
spork's Avatar
Default
My car has never thrown that code since, So I'm guessing I just had some bad gas.
spork is offline
Old 09-01-2004, 01:40 AM   #10
L300Boy
L300Boy's Avatar
Default
Ugh...i did go to the shell station again..
But I guess cleaning of injectors and sensor will not cost anything, compared to replacing the sensor. We'll see how that goes....if the SES pops up I guess i'll look into it further.
Sucks being out of warranty!
L300Boy is offline
Old 09-01-2004, 07:47 AM   #11
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default
I went to Autozone to get my codes read, but he said they weren't allowed to clear them, even if I bought the parts from then to fix it. What's the point of buying parts from them if you have to pay a shop to clear the code anyway?
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline
Old 09-07-2004, 01:34 PM   #12
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Default
Originally posted by spencerb
...What's the point of buying parts from them if you have to pay a shop to clear the code anyway?
Well, I suppose you could look at this two ways: 1) They don't repair cars and that would fall under the "repair" classification, and; 2) The code will clear itself after three drive cycles...if you fixed the problem.
But, I kind of agree with you. There's no harm in clearing a code. If you're subject to emissions testing the system readiness test will indicate any historical or pending codes so that wouldn't be an issue.
Gerry Proctor is offline
Old 09-09-2004, 12:56 PM   #13
piratepress
piratepress is on a distinguished road
piratepress's Avatar
Default
Just do what I did....go on eBay and find a nice, used OBD-II scan tool for under $100. Then you can check it as much as you need and reset the codes if necessary. Just be careful, all your friends and neighbors will want you to check their cars too.
2006 Ion Redline- GMPP Stage 2
Add to piratepress's Reputation
Rate the quality of this post and help piratepress reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
piratepress is offline
Old 09-10-2004, 05:44 PM   #14
L300Boy
L300Boy's Avatar
Default
A friend is letting me borrow an Actron CP9135 OBDII AutoScanner.
Its pretty good, lets you read/erase codes, but it does not show any engine statistics.
L300Boy is offline
Old 09-10-2004, 07:53 PM   #15
elvinrodr
elvinrodr is on a distinguished road
2008 VUE 3.6L
Default
If you need a mass airflo sensor the part # is 90528435 and it is about 110.00. Our shop also recalibrates the computer when this is done. Hope this helps.
91 SL2M
93 SL2A
Add to elvinrodr's Reputation
Rate the quality of this post and help elvinrodr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
elvinrodr is offline
Old 11-08-2004, 03:21 PM   #16
filter905
filter905 is on a distinguished road
Mad Re: Service Engine Soon - P0171 & P0174 HELP?
Saturn called...told me that my Air Mass Flow Sensor is bad and needs to be replaced. The throttle system is off and needs to be calibrated. Total cost on repairs...$747, where can I get this done cheaper? Can I buy this dam sensor OEM and have my mechanic throw it on and recalibrate the computer himself? Please help me....I'm desperate. I've already been tag with over $500 in replacing the F*&(ING oil pan, gasket and oil change because the God Dam oil plug got stripped.
Add to filter905's Reputation
Rate the quality of this post and help filter905 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
filter905 is offline
Old 11-08-2004, 05:12 PM   #17
lostwages_ls2
Default Re: Service Engine Soon - P0171 & P0174 HELP?
$747 is a complete ripoff. The part cost $105 or so. It can't take more than a hour to replace and recalibrate. That means they are trying to charge you over $600/hr labor.
Here is the TSB covering the problem. Print it out and show it to the dealer. Tell them they should fix it for free since it is a known problem. Also, call the area saturn rep and tell him the same thing.
Top - Vehicle
. . Air Flow Meter/Sensor
. . . Technical Service Bulletins
. . . . All Technical Service Bulletins
. . . . . Engine Controls - MIL ON/DTC's P0171/P0174 Set
Notes
BULLETIN NO.: 02-T-48
ISSUE DATE: June, 2002
CATEGORY TYPE: Engine - 16
CATEGORY: Emission Controls
CORPORATION NO.: 02-06-04-036
SUBJECT:
Mass Air Flow Sensor Failure Due to Oil Contamination of Sensor Membrane (Install New Mass Air Flow (MAF) Sensor and Update ECM Calibration)
MODELS AFFECTED:
2000 - 2002 Saturn L Series vehicles equipped with V6 (L81) engines
CONDITION:
Some customers may comment that the SERVICE ENGINE SOON (SES) telltale is illuminated. The vehicle may have DTC(s) P0171/P0174 and/or any MAF sensor or 02 Sensor DTC(s) stored in the ECM memory.
CAUSE:
After the vehicle is shut off, the ECM stays active for a certain period of time before shutting down. During the period of time when the ECM is active, voltage is applied to the MAF sensor. As long as voltage is being applied, heat and air flow will be generated at the MAF sensor. This heat will cause oil particles in the air to adhere to the sensor membrane causing premature failure of the sensor.
CORRECTION:
To correct this condition refer to the Engine/Emission Controls section of the appropriate model year L-Series L81 Engine Service Manual and follow diagnostic for the applicable DTCs. If it is determined that the MAF sensor is at fault, replace the MAF sensor and refer to the following procedure in this bulletin to determine if an updated calibration is required.
IMPORTANT: Before installing new ECM calibration, make sure the Service Stall System (SSS) version is 10.5 or greater.
PROCEDURE:
1. Connect Scan Tool to the vehicle.
2. Navigate to the 3.0L (VIN R) Powertrain Menu.
3. Select ID INFORMATION.
4. Select ENGINE INFORMATION.
5. Read ECM CALIBRATION ID.
2000 Model Year Vehicles
^ If ECM calibration ID number is 610601, 610602, 620101, 620102, 640104, 640301, 640704, or 640901, reprogram the ECM with the latest 2000 model year calibration. Refer to "Service Programming System (SPS)" in the Saturn Service Stall System (SSS)/TECH 2 User Guide for reprogramming procedures.
^ If ECM calibration ID number is not 610601, 610602, 620101, 620102, 640104, 640301, 640704, or 640901, do not reprogram the ECM. The correct calibration is already installed and reprogramming is not required.
2001 Model Year Vehicles
^ If ECM calibration ID number is 630102, 740104, 740302, 740704, or 740901, reprogram the ECM with the latest 2001 model year calibration. Refer to "Service Programming System (SPS)" in the Saturn Service Stall System (SSS)/TECH 2 User Guide for reprogramming procedures.
^ If ECM calibration ID number is not 630102, 740104, 740302, 740704, or 740901, do not reprogram the ECM. The correct calibration is already installed and reprogramming is not required.
2002 Model Year Vehicles
^ If ECM calibration ID number is 840601, 840704, or 840901, reprogram the ECM with the latest 2002 model year calibration. Refer to "Service Programming System (SPS)" in the Saturn Service Stall System (SSS)/TECH 2 User Guide for reprogramming procedures.
^ If ECM calibration ID number is not 840601, 840704, or 840901, do not reprogram the ECM. The correct calibration is already installed and reprogramming is not required.
CLAIM INFORMATION:
To receive credit for this repair during the warranty coverage period, submit a claim through the Saturn Dealer System for J6532 (Sensor, Mass Airflow - R&R or Replace) and if required, J6355 (EE PROM-Reprogramming), or if another procedure is performed, refer to the appropriate Electronic Labor Time Guide for the correct Labor Operation Code and Time. When another procedure is performed that requires EE Prom Reprogramming, J6355 must be claimed as a "Related Line" to that Repair.
Obey the Min Pin
Old 11-09-2004, 10:51 AM   #18
filter905
well...Back from Saturn and got tagged for $537 to replace the Oil Pan, Gasket and fluid change. Labor is $84 per hour. Got the error codes from the mechanic which reads off: P1511,P0171 & P0174. Explained to me that the Mass Air Flow sensor is bad and needs to be replaced. Also, my Throttle Body is bad and is not giving the engine the power it needs...kinda lost me there. Anyways, I was quoted for:
Throttle Body: $360 (part) + ($126 labor)
Mass Air Flow: $132 (part) + ($42 Labor)
Calibration $84
Now correct me if I'm wrong, do I really have to go through Saturn to get all this done. Can I just buy the parts OEM from SaturnParts.com which is less expensive and find myself an ASE Certified mechanic to replace these parts for me? Can anyone help me find a reliable mechanic in the NYC area? Please HELP!
Old 11-09-2004, 12:27 PM   #19
lostwages_ls2
P1511 is a throttle body code. Could be weak return spring. Bad sensor. Or butterfly is binding.
The book standard labor to replace the throttle body is .9 hours. You are being overcharged by .5 hours for that. $360 for the part is about right.
Any garage with the right equipment to "recalibrate" the ECM can do it.
Actually if you are mildly mechanically inclined, you could probably replace the parts, then drive it to the dealer for recalibration. It may not drive perfectly, but it should get there.
Obey the Min Pin
Old 11-09-2004, 01:07 PM   #20
filter905
SaturnParts.com has the Throttle Body for $293.05 & Gasket for $1.50 also the Mass Air Flow sensor for $91.77. Would it make sense for me to buy it from there? Replace the parts and then drive it to Saturn?
P0171 P0174 codes on 3.0 Vue IMkenNY Vue Tech 4 04-03-2009 05:05 AM
vacuum chamber springs? p0171 p0174 vue092107 Vue Tech 3 01-15-2009 08:39 PM
P0507, P0171, P0174 (3.0 V-6 L81) wfransee Vue Tech 1 12-20-2007 05:57 PM
Need advice - P0171 & P0174 Hakman L-Series Tech 8 07-05-2007 02:01 AM
Service Engine Soon P0171 & P0174 HELP? programmer12 L-Series Tech 11 08-31-2004 11:39 PM
