Old 02-25-2004, 10:40 PM   #1
liquiddog976
liquiddog976 is on a distinguished road
Happy 100k miles
I posted on here as liquiddog a couple of years ago. Had just traded in my eagle for a 2001 saturn sc2 and wished for 100k miles. Three years later, 98k is on the odometer and it's still going. I drove it in dallas for 80k miles. The car has been sideways on 75 N at 70 MPH, it has been in the air with all four wheels at 50 mph due to no "dip" sign. (Thanks city of irving)
This car runs like a ak-47. Always seems to work, but not always perfectly.
Serious Maintenance so far:
- 60k miles: intake manifold gasket
- 98k miles: two engine struts broken
Other Maintenance:
- 60k: replaced disc brakes with expensive pads and $15 rotors. Have new break parts with better rotors I'm about to put on to replace cheap warped rotors.
- 95k replaced transmission fluid (forgot @ 5k miles)
- 98k replaced serpentine belt with factory saturn belt
- changed oil, air filter, and replaced spark plugs w/ngk v power at various intervals
- 80k new factory saturn PCV valve ($6), tried oil change shop pcv valve and they do not fit. They pop off and the hose connector is in the wrong spot.
To Do:
struts, suspension is no longer functioning
I'm pretty pleased. I'll post a pic of the odo rolling over 100k.
Add to liquiddog976's Reputation
Rate the quality of this post and help liquiddog976 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
liquiddog976 is offline
Old 02-25-2004, 10:44 PM   #2
Dr. Bob
Dr. Bob is on a distinguished road
Default
Only 100K???
You're just getting it broken in!!!
Add to Dr. Bob's Reputation
Rate the quality of this post and help Dr. Bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr. Bob is offline
Old 02-25-2004, 11:48 PM   #3
LUNCHBOX
LUNCHBOX will become famous soon enough
LUNCHBOX's Avatar
1993 SW2
1993 SC1
Default
Not bad, I have a 93SC with over 250,000. I sold another 93SL with over 180,000 back in 2000. I have done typical maintenence but I also work for a retailer so that helps and we have a great junkyard for pcv valves and lots of other great CHEAPLY priced parts.
1993 SC1.5 - 1993SW2
Add to LUNCHBOX's Reputation
Rate the quality of this post and help LUNCHBOX reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LUNCHBOX is offline
Old 02-26-2004, 09:27 AM   #4
71_307
71_307 is on a distinguished road
Default
100000 miles in 2/3 years damn you do alot of driving
Add to 71_307's Reputation
Rate the quality of this post and help 71_307 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
71_307 is offline
Old 02-26-2004, 09:32 AM   #5
SexyMexi02SC2
SexyMexi02SC2 is on a distinguished road
SexyMexi02SC2's Avatar
Default
*sigh* I'm only on about 20,000 miles but I dream of the day...
glad to see another satisfied Saturn owner. Spread the good word, my man!
S
Xen Xavier
*2002 SC2,black,fully loaded
*Pioneer 8500 h/u
*2 12" Kicker CompVRs
*Polk components
*Rockford 450S amp
*Amer Legacy Cap
*17" Enkei CDR9s
*Toyo FZ4 40ZR17s
...back in black.
Add to SexyMexi02SC2's Reputation
Rate the quality of this post and help SexyMexi02SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SexyMexi02SC2 is offline
Old 02-26-2004, 11:18 AM   #6
SL2Ghost42
SL2Ghost42 is on a distinguished road
SL2Ghost42's Avatar
2000 SL2
2004 VUE 2.4L
Default
Sounds like all the problems you've had, have been absolutely normal. Nothing out of the ordinary. I've had to replace PCV valve, intake manifold gasket, spark plugs, positive battery wire, and serpentine belt. I NEED to replace an engine mount still, and I need new rotors too.
Saturn's cheap rotors i've heard good and bad about, they do take a while to go out but they are pretty cheap.
I'm on 48,800 miles now, and this is the first rotor replacement I think. Maybe second, but not sure.
Your intake manifold gasket lasted a REALLY LONG TIME! It's only supposed to last I think they said "35,000". Mine made it to "46000". But 60000? WOW! You got a nice one there.
2000 SL2 107,000 "Little Saturn" - Daily Driver
2004 Vue 125,000 "The Vue" - Work Vehicle
Add to SL2Ghost42's Reputation
Rate the quality of this post and help SL2Ghost42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2Ghost42 is offline
Old 02-26-2004, 12:54 PM   #7
SLVR_Saturn
SLVR_Saturn is on a distinguished road
SLVR_Saturn's Avatar
Default
Im at about 28K, *sigh*, I'll reach 100K someday
Add to SLVR_Saturn's Reputation
Rate the quality of this post and help SLVR_Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLVR_Saturn is offline
Old 02-26-2004, 01:21 PM   #8
SW2Muck
SW2Muck is on a distinguished road
SW2Muck's Avatar
1999 SW2
Default
My old SW2 got crunched at 98K. My current had 37K when I bought it back in June, it now has 48K on it. I got a ways to go!
Andrew "SW2Muck" Muck
"Do you know your place, in the big charade? Are you more than they?"
-Bad Religion
Add to SW2Muck's Reputation
Rate the quality of this post and help SW2Muck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SW2Muck is offline
Old 02-26-2004, 02:08 PM   #9
Capone72
Capone72 is on a distinguished road
Default
I really wanted mine to see 200000...but 193656 was as far as I got...She had alot of life left in her though..
Add to Capone72's Reputation
Rate the quality of this post and help Capone72 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Capone72 is offline
Old 02-26-2004, 06:01 PM   #10
Petey
Petey is on a distinguished road
Petey's Avatar
2004 VUE 3.5L
Default
intake manifold gasket?! Mine has 108K and never been changed knock on wood, its a 97 sl2. I have changed out the idler pulley and fixed a leaking sunroof thats about it
97 SL2 5-speed 190K, black & gold w/ gold trim, power package, sunroof, spoiler
06 TrailBlazer 90K
Add to Petey's Reputation
Rate the quality of this post and help Petey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Petey is offline
Old 02-26-2004, 09:28 PM   #11
ProDarwin
ProDarwin is on a distinguished road
Default
As long as you do the maitenence, you are good for another 100k easy. I'm betting with minor maitenance, mine would break 300k, but with the amount of driving I do, and the lack of a garage, I'm not going to try.
The only problem I have with my car right now is just the tires suck.
Anyways, good luck on your way to the 200k mark.
-Travis
Add to ProDarwin's Reputation
Rate the quality of this post and help ProDarwin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProDarwin is offline
Old 02-27-2004, 01:11 PM   #12
sonicsaturn99
sonicsaturn99 is on a distinguished road
Default
i'd love to reach 100,000!!!!! i keep blowing up engines at about 87,000!
Add to sonicsaturn99's Reputation
Rate the quality of this post and help sonicsaturn99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sonicsaturn99 is offline
Old 02-28-2004, 11:17 AM   #13
liquiddog976
Default
Dunlop Sport A2's definitely blow away the stock tires. I can ignore rain with them.
And thanks, it would be nice if it kept going that long.
Old 03-18-2004, 02:32 PM   #14
liquiddog976
Default
Update:
There is now 100,070 miles. I am trying to figure out how to get a picture. Hopefully my webcam still works.
Status:
  • Have KYB struts and Saturn strut mounts. Taking a pause before putting them on and looking at the possibility of Eibach springs.
  • Needs rear drum brakes. Took to my usual tire place and they wanted $400 for aftermarket drums, wheel cylinders, shoes, and installation. Planning to get the parts from a online Saturn dealer and have my neighbor show me how to do drum brakes for $100. (He's ASE certified in brakes) Total cost: ~$300 for the job with *original* parts.
  • After furthur research, realized same tire place has been charging me a little over market for my Dunlop Sport A2's. Currently staring like a little kid at the Tire Rack/Goodyear solution which looks much cheaper.
  • Weird stumble in idle after the engine gets to normal operating temperature. Likely first try: replacing aftermarket wires with saturn wires, new spark plugs, coil inspection. Hopefully that will fix it
  • It needed an O2 sensor. Saturn put it on. (can we say warranty?
  • Currently getting 30.5 MPG. Daily driving scenario is wading through the parking lot that "they" claim is a highway, with short bursts of speed up to 70 for maybe a minute. Then back to 5 MPH. Some smooth highway driving during non-peak hours, but limited.
Old 03-18-2004, 04:53 PM   #15
Craig
Craig is on a distinguished road
Default
Well, my '95 SW2 has almost 184,000 on it and still going strong. Aside from the normal wear and tear items, it needed a new EGR valve at 141,000, a new motor mount at 150,000, a clutch at 171,000, and an output shaft bearing (transmission rebuild to do that) at 175,000. The muffler went at 115,000, so I put a Borla on it and eventually a '92 header and SPS stainless steel cat-back. Got a little over 33mpg on my last tank, pretty good for this time of year with all the snow and crap we got.
Add to Craig's Reputation
Rate the quality of this post and help Craig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Craig is offline
Old 03-18-2004, 09:49 PM   #16
purepwrSL2
purepwrSL2 is on a distinguished road
purepwrSL2's Avatar
Default
wow ! 100k in very periods of time ?? my satty only got 56k miles on it and only 10yrs old. where you go piling up that many miles in short yrs time frame ?? You must been travel around the world with it LOL . I like to see my car clocks 100k too , but it will takes a while to see that numbers,, i guess somewhere pass the yr 2010 to see my car clicks it over 100k
Add to purepwrSL2's Reputation
Rate the quality of this post and help purepwrSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
purepwrSL2 is offline
Old 03-18-2004, 10:18 PM   #17
Kronos70
Kronos70 is on a distinguished road
Thumbs Up
My '93 SL1 had 137k when my friend "gave" her to me... it cost me $700 to get her running again. It seems someone :o: forgot to put the oil cap back on and it ran a while with no oil. The Timing chain, and gear needed replacement, plus the misc odds & ends.
She starts up fine, and sometimes there's a little valve noise untill the oil starts to flow, but she seems to run fine...except when I step on it, I sometimes see blue smoke comming out the tailpipe. Saturn shop said it'd cost me $2200 to rebuild the engine. He also said that if I keep on top of the oil lose, that it shouldn't be a problem.
Now I've put over 700 miles on her, and she's gotten two oil changes, because the oil gets dark quick. I guess that's because of either the oil rings, OR the valve seals are bad...what do you all think? any guesses?
Oh! last thing, anyone know of any place where I can get the control module that deals with the seatbelts cheaper than $150 from the dealer? It's not too big of a deal, but when I open my door and the car is off, the chime goes off... hee hee the control module is seeing things backwords.
Add to Kronos70's Reputation
Rate the quality of this post and help Kronos70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kronos70 is offline
Old 03-18-2004, 11:41 PM   #18
liquiddog976
Default
Craig,
The miles were accumulated from driving on I35 in between Dallas and Austin as well as to Sam Houston National Forest and a few areas north of Houston from Dallas. My car has never left Texas. Most of them were the Dallas<->Austin drive. I put so many miles on the car doing that drive I finally just moved here to Austin. I currently do about 1.5k miles/month, but in Texas how could you not? That's just going back and forth to work and seeing friends in and around town.
Amazingly I only crashed one time in that period. She (her) was going thru a parking lot in a black car in the dark (tornado season) without her lights on, going really fast. I nudged her large metal car in the side at about 5 MPH. I had engaged the clutch but had not yet commited to going forward. A few months later my headlight started accumulating moisture. I got a new assembly and put it on myself in five minutes. You should have seen her car... Creased metal across two body panels.
I did mention to her she might look into getting a plastic car since they just bounce when they hit things. HAHA
Old 03-19-2004, 12:31 AM   #19
94sc293sl1
94sc293sl1 is on a distinguished road
94sc293sl1's Avatar
1994 SC2
Default
Congrats on hitting 100K! My SC2 is a '94, and I finally hit 90K last weekend, LOL.
As for tires, I got some Falken Ziex 512s at Discount Tire last fall, just over $300 including lifetime free replacement warranty. They've seemed good so far, and are pretty highly rated.
Craig
Saturn owner no longer as of 12/21/05, sold my SC2.
www.insidetrackmagazine.com
Add to 94sc293sl1's Reputation
Rate the quality of this post and help 94sc293sl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc293sl1 is offline
Old 03-19-2004, 01:00 AM   #20
liquiddog976
Default
I remember getting a full set of the dunlops at around 20k miles because I hated the originals. I wore those out eventually and one set went completely bald. I replaced that set with sumitomos. I don't even want to discuss these tires which are still a fungus on my car. The other pair of dunlops finally went bald and contained flat spots from being locked up hard once. I replaced those with more dunlops. I have the sumitomos up front where they will hopefully wear out after 20k miles or so. They aren't really that bad, I just got spoiled by the dry/wet traction and handling of the dunlops and now I hate anything less.
I used to put yokohama on my eagle and I never cared for those either. They felt stiff compared to goodyear tires which came with it.
Reliable @ 100K Miles Coolabie Vue General 12 05-10-2008 07:56 AM
first oil change at 100k miles?? charlien63 Ion General 24 10-20-2007 06:30 PM
3.0 V6: Replace Timing Belt at 100K Miles? canoecrafter L-Series Tech 5 02-24-2007 02:08 AM
FS 03 Ion 2 sedan w/100k miles warranty!! penjaja Classifieds 11 07-23-2004 09:21 PM
Just hit 100k miles! VTHokie00SL2 General Saturn Discussion 6 07-27-2001 11:19 AM
