Old 02-02-2004, 05:13 PM   #1
Isophorone
Isophorone is on a distinguished road
Default Rear washer - no spray
Hi all,
We have a 1999 SW2 with 48,000 miles on it. A few months ago, I noticed that the rear wiper works, but no fluid comes out of the washer nozzle. The spray motor sounds like it is trying to spray when I turn the knob. I tried using some wire to unblock it with no success. Any ideas? Now that it's winter the rear window is really dirty!
Also, How do you change the rear wiper blade (or even lift it up to clean off at a gas station)? Hte assembly does not lift up like the front ones do.
Thanks for any help you can give.
RJ
Isophorone is offline
Old 02-02-2004, 07:23 PM   #2
SLVR_Saturn
SLVR_Saturn is on a distinguished road
SLVR_Saturn's Avatar
Default
does the car sit outside? The line might be frozen.
not too long ago I had the same problem with my front sprayers :o: I was able to bring it in over night into a heated garage and tried it again the next morning and worked fine and has since that time.
SLVR_Saturn is offline
Old 02-02-2004, 07:45 PM   #3
Craig
Craig is on a distinguished road
Default
At least your rear wiper works...the one on my '95 SW2 quit five or six years ago. But I'm getting a '94 SW2 parts car, so I'm hoping the wiper works on that one so I can swap it.
Craig is offline
Old 02-03-2004, 11:08 AM   #4
Isophorone
Default
The car generally sits in a garage. Also, the problem started before the weather turned cold. The wiper itself works, it's just the washer fluid that doesn't come out. The front wipers and washer work fine.
Also, if you know how to lift up the rear wiper the way you lift the front ones, please let me know.
Old 02-03-2004, 11:24 AM   #5
SLVR_Saturn
Default
It may be that there just wasn't enough washer fluid to in the line so it froze up. As far as I can remember from the manual that rear wiper doesn't lift nearly as far as the front ones do.
(I'm doing this off of memory so I could be wrong, my car doesn't have a rear wiper, but, like I said I think I remember something in the manual about that....)
Old 02-03-2004, 02:53 PM   #6
eljefino
eljefino's Avatar
1995 SW1
Default
When mine broke it was a plastic adaptor between the rubber hose and wiper shaft, inside the tailgate. Symptoms included blue stuff dribbling on the bumper. Fixing it looks like a pain so I turn on the wiper then run back there with a coffee cup full of water...
eljefino is offline
Old 02-04-2004, 10:17 AM   #7
Ernie's 00SWP
Ernie's 00SWP will become famous soon enough
Ernie's 00SWP's Avatar
2000 SWP
Default
You may just need to blow the line out... My SWP's did the same thing. Took it to Saturn Dealer and they found a spider had made her home in it causing it to clog up...
Ernie's 00SWP
Ernie's 00SWP is offline
Old 02-04-2004, 06:38 PM   #8
dieseljack
dieseljack is on a distinguished road
Default
If it's broken, there's an inexpensive repair kit available from the dealer. It beats throwing $270.00 + for a motor assembly.
dieseljack is offline
my windshield washer doesnt spray at all :( Gnfanatic S-Series General 5 10-31-2008 12:47 AM
Rear wiper nozzle won't spray goldmember S-Series Tech 8 12-21-2007 04:38 PM
Rear Window Spray Nozzle - dribble or spray? mellissam Vue General 10 12-05-2006 12:51 PM
Rear washer, early SW cityhawk S-Series Tech 12 10-29-2005 06:54 AM
Winsheild Washer Spray ricksLS1 Vue General 0 11-02-2003 08:45 PM
