Old 01-28-2004, 11:08 AM   #1
Red94sc2
Red94sc2 is on a distinguished road
Red94sc2's Avatar
Default Idling
I had posted a thread earlier about an idling problem I have been having. It was suggested that the cracked vacuum line I had was the problem but I have since replaced that and the problem is still there.
I have cleaned the T-Body several times including the TPS and the IAC. I also cleaned the EGR valve.
What the car is doing is that when first started, it will idle between 1000 and 1500RPM. After driving a while, when you come to a stop it will dip to 500rpm, back up to between 1000 and 1500rpm a few times then will sit and idle between 1000 and 1500rpms.
What would cause this variation in idling? Could it be the IAC? I disconnected the IAC to see what happens and it idled with no flucuation but at 3000rpms since it was not connected. I have cleaned the IAC and TPS. Could the IAC have gone bad? Someone had mentioned the ECTS. Would the ECTS cause a flucuation and high idle. I have not found any more vacuum leaks.
Thanks for any input.......
Add to Red94sc2's Reputation
Rate the quality of this post and help Red94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red94sc2 is offline
Old 01-28-2004, 01:06 PM   #2
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default
It's unlikely, but check for leaks on the air intake tubing, especially at the crankcase vent hose (the hose coming from the cam cover). I forget to connect this hose before, and my car displayed these symptoms. The revs would dive so bad I'd have to rev the engine to keep it running.
'00 SL2m- daily-driver, 162K miles
'97 SL2m- wife's daily-driver, 183K miles
Add to Twin_Cam's Reputation
Rate the quality of this post and help Twin_Cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twin_Cam is offline
Old 01-28-2004, 09:37 PM   #3
wolfman
wolfman's Avatar
Default
To confirm or deny that you have a bad IAC valve, do this:
Start the car and allow it to warm up to normal operating temp.
Turn off the car and disconnect the IAC electrical connector
Plug the IAC passage in the lower throttle body throat with the IAC valve STILL INSTALLED (A piece of duct tape will do, or your finger pressed firmly to seal the pencil sized hole)
Restart the car.
IF with the IAC disconnected and port plugged the car idles around 600 RPM or so warmed up, the IAC is bad. If it is substancially higher than that, and YOU HAVE NOT messed with the throttle stop screw, you have a vacuum leak that the IAC has been trying to compensate for resulting in the odd idle behavior.
Add to wolfman's Reputation
wolfman is offline
Old 01-29-2004, 06:25 AM   #4
Red94sc2
Red94sc2's Avatar
Default
Thanks for the tip. Ill try that today after work..... Thanks again....
Red94sc2 is offline
Old 02-06-2004, 09:19 AM   #5
Red94sc2
Red94sc2's Avatar
Default
Got the problem fixed! It was not the IAC but it was the ECTS!!! I had my valve cover gasket replaced in my parking lot at work by a mechanic at my local Saturn dealership that works on the side. He looked at the idle and said, like most of you have said, that the ECTS may be bad. I replaced it with one from AutoZone. The old one was cracked on the tip! As soon as I started, it idled like brand new and havent had a problem since!!!! Ill be replacing the one on my 95 SL2 soon just in case.......
Red94sc2 is offline
idling problems CMSchops S-Series Tech 4 10-17-2006 10:33 AM
idling problems CMSchops S-Series Tech 11 09-28-2006 08:30 AM
idling problems CMSchops General Saturn Discussion 1 09-26-2006 02:16 PM
Ok, now what? Or, idling issues... mdurisseau S-Series Tech 9 05-04-2006 10:30 AM
Idling High while in P or N glaukus S-Series General 7 03-14-2005 10:06 PM
