Old 01-06-2004, 04:57 PM   #1
LenZelinski
LenZelinski is on a distinguished road
Default P0708 Transmission Range Sensor Circuit High Input
is this the neutral safety switch?
it's for a 1996 SL1,the service light comes on almost everytime i start it.sometimes likes just now it didn't come on.
is it easy to replace?
i saw about adjusting it but i will just replace it because it is cheap and then i don't have to see the service light come on again.
Add to LenZelinski's Reputation
Rate the quality of this post and help LenZelinski reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LenZelinski is offline
Old 01-06-2004, 06:43 PM   #2
TedL
TedL is on a distinguished road
Default
The FSM lists this as "No Data" from the neutral safety switch, and notes that a disconnected switch will set this code.
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 01-06-2004, 07:35 PM   #3
LenZelinski
Default
thanks,the manual i have doesn't go into obdII at all.
all the connectors are fine,the switch is probably worn.
got a new one coming from saturnparts.com,light hasn't come on today since i started it early today(figures).
Old 01-06-2004, 08:53 PM   #4
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
the switch is adjustable, you might want to check that before you go ahead and replace it...
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 01-06-2004, 09:08 PM   #5
LenZelinski
Default
yeah but i figured it looks easy to change and then i won't have to find a code scanner the next time the light comes on to make sure it's just the neutral safety switch.
Old 01-07-2004, 12:12 PM   #6
wolfman
wolfman's Avatar
Default
I will only add that if you are getting the code at startup, it is probably the PARK portion of the switch with the problem, although it is essentially adjusted as a unit.
Add to wolfman's Reputation
wolfman is offline
Old 01-07-2004, 12:23 PM   #7
LenZelinski
Default
of course it hasn't come on once since i posted.
gonna change it anyhow,ordered it already.
just want to know if it just unbolts easily.
i don't want to unbolt it and have some small part drop out and disappear.
Saturn Trouble code PO706 Transmission range sensor...? ivymotorsports S-Series Tech 31 06-02-2012 11:14 PM
transmission range sensor? bdobraj S-Series General 5 03-09-2012 04:03 PM
2002 SL1 Transmission issues, "reverse slam", P0708 code, transmission range sensor mt_spiffy S-Series Tech 20 12-14-2009 02:17 PM
transmission range sensor adjustment jeepinwi Ion Tech 1 01-27-2009 03:33 PM
CODE P0714: Transmission Fluid Temperature Sensor Circuit Intermittent mncoeltj S-Series Tech 3 02-19-2006 10:14 AM
