Old 12-20-2003, 10:04 PM   #1
Actaeon
Actaeon is on a distinguished road
Actaeon's Avatar
Default Key stuck, very hard to remove key from ignition...
I can stick my key in just fine, but when I turn to remove the key from the ignition, it won't leave.
Usually, I have to let it sit for a minute or two, then twist it back and forth, and then it'll get out. Today it wouldn't do it, and I was 10 minutes late for work, stuck in the parking lot.
Its rather hard to explain this problem, but its a huge pain in the ass!
Its on a 97 SC2 Auto.
Thanks
Jonathan
Add to Actaeon's Reputation
Rate the quality of this post and help Actaeon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Actaeon is offline
Old 12-20-2003, 10:14 PM   #2
wolfman
wolfman's Avatar
Default
You "may" just need to get a new key CUT (not copied) at your local Saturn retailer to the key code for the car. Before doing that however, take a trip to your local hardware store (or Walmart maybe?) and purchase a bottle of "Lockease" It is a solvent based graphite lock lubricant that may be all thats needed to free things up. DO NOT use WD40 or 3in1 or other oil! It may work but will result in the lock cylinder actually drying out or gunking up and getting stiffer over time. The lockease washes out crud with a solvent that evaporates leaving a "dry" graphite lubricant behind that will not gum up the lock or attract dirt. It has worked very well for me in the past...
Add to wolfman's Reputation
wolfman is offline
Old 12-20-2003, 10:36 PM   #3
Actaeon
Actaeon's Avatar
Default
Thanks for the advice Wolfman, but maybe I was not clear in my original post. Or perhaps you understood me perfectly, but I'll make it clear.
I don't believe the key is the problem, its just that the ignition won't let go of the key. I can turn it anywhere, its just the ignition won't release the key. No matter where its turned, only if I'm lucky, after waiting a little while, it will let the key release.
Actaeon is offline
Old 12-20-2003, 10:38 PM   #4
wolfman
wolfman's Avatar
Default
That suggests that the pins in the lock cylinder that the key acts on are sticking. Lubing the lock with the product described above should do the trick.
wolfman is offline
Old 12-20-2003, 10:42 PM   #5
Actaeon
Actaeon's Avatar
Default
Wow, you are quick! I'll head to walmart and see if they have some, if not, discount auto tomorrow.
Thanks again Wolfman,
Jonathan
Actaeon is offline
Old 12-20-2003, 11:08 PM   #6
baskerj
baskerj is on a distinguished road
Default
I see you're in Orlando too...if you didn't go to Walmart...Publix and Winn Dixie also typically have graphite lubricant in the small auto section they have...
Add to baskerj's Reputation
Rate the quality of this post and help baskerj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
baskerj is offline
Old 12-20-2003, 11:16 PM   #7
Actaeon
Actaeon's Avatar
Default
Yay! Another Florida member...
I live in Kissimmee to be more exact. I'm goign to check out WalMart later tonight to see if they have this stuff, too lazy to stop by now though.
Thanks
Jonathan
Actaeon is offline
Old 12-21-2003, 12:08 AM   #8
Dach
Dach is on a distinguished road
Default
I think you may be having a problem with your shift interlock solenoid. Try moving the shifter from P to R and back when it's stuck, if it comes out easily that's your culprit. It's not an easy fix but there are several posts that describe the diy repair. Do a search on shift interlock and you'll see.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline
How to remove ignition key cylinder with broken key in the cylinder, L-series? dejavu48 L-Series Tech 0 11-15-2008 11:46 AM
Key stuck in ignition Scott Doscher S-Series Tech 13 03-01-2007 01:05 PM
key stuck in ignition msgould S-Series General 10 11-29-2006 09:08 AM
Key stuck in ignition grownbratt1 S-Series Tech 3 10-13-2005 10:22 AM
Spare key gets stuck in ignition, main key doesn't 94sc293sl1 S-Series Tech 7 07-12-2004 12:03 AM
