Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 12-20-2003, 03:14 PM   #1
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default Acceleration!
Acceleration
Stolen from another car forum:
A lesson in acceleration:
First, some useful info:
*One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than
the first 4 rows at the Daytona 500.
*Under full throttle, a Top Fuel dragster engine consumes 1 1/2 gallons of
nitromethane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
*A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the
dragster's supercharger.
*With 3000 CFM of air being rammed in by the supercharger on overdrive, the
fuel mixture is compressed into a near-solid form before ignition. Cylinders
run on the verge of hydraulic lock at full throttle.
*At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the flame
front temperature measure 7050 degrees F.
*Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night if raw burning hydrogen, dissociated from atmospheric water
vapor by the searing exhaust gases.
*Dual magnetos supply 44 amps to each spark plug. This is the output of an
arc welder in each cylinder.
*Spark plug electrodes are totally consumed during a pass. After 1/2 way,
the engine is dieseling from compression plus the glow of exhaust valves at
1400 degrees F. The engine can only be shut down by cutting the fuel flow.
*If spark momentarily fails early in the run, unburned nitro builds up in
the affected cylinders and then explodes with sufficient force to blow
cylinder heads off the block in pieces or split the block in half.
*In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate at an
average of over 4g's. In order to reach 200 mph well before half-track, the
launch acceleration approaches 8G's.
*Dragsters reach over 300 mph before you have completed reading this
sentence.
*Top Fuel engines turn approximately 540 revolutions from light to light.
*Including the burnout, the engine must only survive 900 revolutions under
load.
*The red-line is actually quite high at 9500 rpm.
*The bottom line: Assuming all the equipment is paid off, the crew worked
for free, and for once, NOTHING BLOWS UP, each run costs an estimated $1,000
per second. The current Top Fuel dragster elapsed time record is 4.441
seconds for the quarter mile (10/5/03, Tony Schumacher.) The top speed
record is 333.00 mph (533 km/h) as measured over the last 66' of the run
(9/28/03 Doug Kalitta.)
Putting all this into perspective:
You are riding the average $250,000 Honda Moto GP bike. Over a mile up the
road, a Top Fuel dragster is staged and ready to launch down a quarter mile
strip as you pass. You have the advantage of a flying start. You run the
RC211V hard up through the gears and blast across the starting line and past
the dragster at an honest 200 mph (293 ft/sec.) The "tree" goes green for
both of you at that moment. The dragster launches and starts after you. You
keep the throttle hard open, but you hear an incredibly brutal whine that
sears your eardrums and within 3 seconds the dragster catches and passes
you. He beats you to the finish line, a quarter mile away from where you
just passed.
Think about it, from a standing start the dragster had spotted you 200 mph
and not only caught, but nearly blasted you off the road when he passed you
within a mere 1320 foot long race course.
That folks, is acceleration!
Add to SLeepr's Reputation
Rate the quality of this post and help SLeepr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLeepr is offline
Old 12-20-2003, 05:48 PM   #2
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default
:o:
Awesome facts. Very interesting.
'00 SL2m- DD, 186K miles
'05 Honda CR-V- wife's DD and my upright bass hauler
'84 Honda CB650SC Nighthawk- toy
Add to Twin_Cam's Reputation
Rate the quality of this post and help Twin_Cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twin_Cam is offline
Old 12-20-2003, 05:56 PM   #3
TommyH
TommyH is on a distinguished road
Default
That's actually one of the coolest things I've read in a long time!
Add to TommyH's Reputation
Rate the quality of this post and help TommyH reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TommyH is offline
Old 12-20-2003, 08:54 PM   #4
chance 01-sc2
chance 01-sc2 is on a distinguished road
Default
i a little confused ( and trust me, im so into drag racing that it is almost a mental disorder) about the number of turnovers that the enging has to survive. those things are geared to hit redline at the exact moment that they cross the traps. they have to survive more than 900 revolutions. it is a mathmaticle imposability. especialy including the burnout. i may be way off on this so please do not get upset or anything like that. i probably just read it the wrong way or something.
Add to chance 01-sc2's Reputation
Rate the quality of this post and help chance 01-sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chance 01-sc2 is offline
Old 12-21-2003, 12:42 AM   #5
LB_BlueVue
LB_BlueVue is on a distinguished road
LB_BlueVue's Avatar
2003 VUE 2.2L
Default
Not at all upset, but the math does work....
9500 rpm / 60seconds = 158.33 rev/second X 4.441 seconds = 703.16 revolutions to cover 1/4 mile, IF the engine redlines the ENTIRE track. Which leaves at least 196 revolutions for burnout. That's almost six seconds at a 2k idle, or over one second if it's still at redline.
Isn't math great? :
LB_BlueVue
Silver '05 FWD V6 Automatic
Replaced Blue '03 FWD I4 VTi
Add to LB_BlueVue's Reputation
Rate the quality of this post and help LB_BlueVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LB_BlueVue is offline
Old 12-21-2003, 06:59 PM   #6
chance 01-sc2
Default
ooh crap, my bad. i wasnt thinking clearly then i guess. sorry bout that.
Old 12-21-2003, 11:03 PM   #7
tightsaturn96
tightsaturn96 is on a distinguished road
tightsaturn96's Avatar
Default
That is very bad ass!
Add to tightsaturn96's Reputation
Rate the quality of this post and help tightsaturn96 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tightsaturn96 is offline
Old 12-22-2003, 03:15 AM   #8
Marshall
Marshall is on a distinguished road
Marshall's Avatar
Default
One inaccuracy I found is this:
"Under full throttle, a Top Fuel dragster engine consumes 1 1/2 gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced"
This doesn't seem right at all, or is at least very misleading.
A top fuel dragster makes about 6,500 hp. Just one jet engine on a 747 produces about 50,000+ hp. It has 4 of these engines. Fully loaded 747's don't fly using only 1 engine. You're looking at 200,000+ hp compared to 6,500 hp.
Maybe the original author got a bit ahead of himself, and posted the fuel consumption rate of only one 747 engine at the economy cruising speed. Because a fully loaded 747 isn't going to get into the air with only 6,500 hp, I'll tell you that much...
Add to Marshall's Reputation
Rate the quality of this post and help Marshall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Marshall is offline
Old 12-23-2003, 12:12 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
Default
all you need to know is f=ma. a=f/m. a is acceleration, f is force (torque), m is mass (weight).
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 12-23-2003, 09:57 PM   #10
feej
feej is on a distinguished road
1992 SL
Default
almost t(tourque)=f(force) x(cross multipy, multiply the perpendicular components) r(radius)
but yeah it is a direct proportion between force and tourque
Add to feej's Reputation
Rate the quality of this post and help feej reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
feej is offline
A/C and Acceleration auralsphere S-Series General 5 05-21-2009 09:20 AM
No acceleration Onion S-Series Tech 4 12-07-2008 09:39 PM
acceleration... bskicrash1 S-Series General 11 06-03-2006 10:32 PM
acceleration gaums Mods and Performance 3 07-23-2005 01:35 PM
Acceleration gaums L-Series General 2 07-23-2005 12:56 PM
