Old 12-18-2003, 12:29 AM   #1
amazinghl
Wrench Getting Codes from a OBD I Saturn
Use a paper clip to jumper Terminal A and B of the ALDL *Assembly Line Diagnostic Link* which is above your left knee.
Terminal A is an interal ground and is the top right terminal in the connector. Terminal B is directly adjacent and to the left of Terminal A.
Turn the ignition to ON.
All codes are 2 digits between 11 and 99. Codes are displayed on the SES light by flashing the light with short and long pauses to distinguish digits of one code from digits of another. The short pause is used between digits of the same code, long pauses are between codes. Also, each code is flashed three times before going to the next code.
For example, the sequence of code 12 will be: flash, pause, flash-flash, long pause, then repeat 2 times. If Code 12 is not displayed, the self-diagnostic pogram i snot functioning properly.
If only Code 12 is displayed, no system malfunctions have been stored.
Any existing system fault codes are displayed in order from low to high, except for Code 11.
On vehicles with an automatic transaxle and on which exist stored transaxle codes, Code 11 will be displayed last, then the SHIFT TO D2 light will begin flashing transaxle codes of flags.
*I have no idea what SHIFT TO D2 light is*
When all engine codes have been displayed, Code 12 will flash again.
Diagnostic Codes
11. Transaxle Codes present
12. Diagnostic System Check
13. Oxygen sensor, circuit open or not ready
14. CTS circuit, out of range high
15. CTS circuit, out of range low
17. PCM fault, pullup resistor
19. 6x signal fault, no 6x signal between reference pulses
21. TPS circuit, out of range high
22. TPS circuit, out of range low
23. ATS circuit, out range low
24. VSS circuit, no signal
25. ATS circuit, out or range high
26. Quad Driver output fault
32. EGR system fault
33. MAP sensor circuit, out of range high
34. MAP sensor circuit, out of range low
35. IAC valve, rpm out of range
41A EST circuit open
41B EST circuit shorted
42A Bypass circuit grounded
42B Bypass circuit open
42C Bypass circuit shorted
41. EST bypass, open or shorted
42. EST bypass, open or shorted
43. ECS (knock sensor) circuit open or shorted
44. Oxygen sensor indicates system lean
45. Oxygen sensor indicates system rich
46. Power steering pressure switch circuit, open
49. Idle rpm out of limit high (vacuum leak)
51. PCM memory error
55. A/D converter error in PCM
81. ABS message fault (1993 vehicles with TCS)
82 PCM internal communication fault
Diagnostic Flags
27. Quick quad driver output fault (1993 only)
48. Reference imput intermittent or noisy
52. Battery voltage out of range
53. ESC knock present
54. Five volt reference ground
58. Battery voltage unstable
61. 6x signal fault
63. Option check sum error
67. Handwheel sensor circuit fault
71. Cooling system temperature high
72. Coolinng system temeprature low
73. CTS sensor unstable
74. CTS/transaxle temperatuer sensor ratio error
76. ATS sensor unstable
83. Low coolant (1993 only)
From Chilton's 91-93 repair manual.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 03-08-2004, 10:29 AM   #2
pcandpc
pcandpc is on a distinguished road
Default
All I get is a code 12.
Add to pcandpc's Reputation
Rate the quality of this post and help pcandpc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pcandpc is offline
Old 09-08-2004, 12:02 AM   #3
LinuxPunk
LinuxPunk is on a distinguished road
Default
Amazinghl i have a little questions for you.
I brought my car into the mechanic to get what i thought was code 15 CTS low reading or whatever. And he asked me how i read the code i told him and he began to get upset saying that thats not the right way to read the code short circuit the computer. You could've killed you computer and thats quite expenisve to replace. My question is since i got code 15 how did he get code 73? i dont understand? Could you please maybe clear this one up? Thank-you
LinuxPunk
Add to LinuxPunk's Reputation
Rate the quality of this post and help LinuxPunk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LinuxPunk is offline
Old 09-08-2004, 08:10 AM   #4
Razorbak
Razorbak's Avatar
Default
What year and model is your car? Are you sure it is OBD-I, and not OBD-II?
Add to Razorbak's Reputation
Razorbak is offline
Old 09-08-2004, 08:54 AM   #5
LinuxPunk
Default
Yes its a 94 SL
LinuxPunk
Old 12-28-2004, 04:47 PM   #6
Luke
Luke's Avatar
Default Re: How to get codes from a OBD I saturn...
As I just referenced this dialogue, I thought it best to update & correct the concern expressed below.
Fm >> LinuxPunk <<
>I brought my car into the mechanic to get what i thought was code 15 CTS low reading or whatever. And he asked me how i read the code i told him and he began to get upset saying that thats not the right way to read the code short circuit the computer. You could've killed you computer and thats quite expenisve to replace.<...
This procedure is the correct way to read the codes; one can actually purchase various units which are plugged into the slots, should you be concerned over using a paper clip.
Have no fear.......
Add to Luke's Reputation
Luke is offline
Old 02-05-2005, 07:41 PM   #7
green
green is on a distinguished road
Default Re: Getting Codes from a OBD I Saturn
Using a paper clip is a very easy and cheap way to read codes on my 95. Thanks. I read codes 12 and 26. The horn does not work. What does code 26 mean in simple English?
Add to green's Reputation
Rate the quality of this post and help green reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
green is offline
Old 02-05-2005, 08:41 PM   #8
Do a search in the "S-Series" and "S-Series Tech Talk" forums on "Quad driver", and an answer will emerge, I'm sure. BTW, from here, you should discuss this further on one of the above-mentioned forums; we're straying from the purpose of "How To".
Add to madpogue's Reputation
madpogue is offline
Help with OBD Codes AQuinn19 S-Series Tech 10 12-17-2009 12:39 PM
OBD I codes sat-vic S-Series Tech 19 12-07-2008 12:14 AM
obd codes SWargy S-Series General 20 10-15-2008 04:13 PM
OBD II codes santro L-Series General 6 09-27-2005 09:33 PM
Saturn Specific OBD II Codes (revisited) Walburger_97SC2M Miscellaneous Tech 3 05-28-2000 04:55 AM
