Old 11-19-2022, 11:48 AM   #1
Astra08
Astra08 is a jewel in the roughAstra08 is a jewel in the roughAstra08 is a jewel in the rough
Astra08's Avatar
2008 Astra XR
Default Reset oil life montor
Thanks to the lack of driving over the past few years, it's been ages since I've had to do this, and the 0 SP indicator just came on.
I've tried the process listed in the manual but no luck, but I thought there was something else involved which the manual didn't list?
Astra08 is offline   Reply With Quote
Old 11-19-2022, 02:59 PM   #2
AstraFasta
Default Re: Reset oil life montor
The reset procedure in the manual seems to be wrong. See this post
http://www.saturnfans.com/forums/sho...d.php?t=137477
Old 11-21-2022, 12:10 PM   #3
Astra08
Astra08's Avatar
2008 Astra XR
Thanks, that still didn't work, but it might be something with the replacement ECM in my vehicle. I seem to remember following these steps to reset it with the prior computer.
Here are the steps in case anyone needs them:
1. Turn the ignition key to LOCK/OFF.
2. Press the instrument panel cluster stem until the odometer is displayed, then release the stem.
3. Re-Press and hold the cluster stem until the letters InSP are displayed.
4. Press and hold the brake pedal down, Hold the cluster stem down and turn the ignition key to ON/RUN.
5. The letters InSP in the instrument panel cluster display will flash.
6. Keep the cluster stem down for at least 10 seconds and then release the stem and the brake pedal when the message "new remaining mileage" is displayed.
Old 11-21-2022, 12:48 PM   #4
AstraFasta
Sometimes it takes several tries for it to work. . .
how to reset oil life joebear1 Outlook General 12 09-06-2012 07:48 AM
Help: Oil Life Reset dmoser Astra Tech 10 12-03-2010 09:59 PM
oil life reset procedure Toms XR3 Astra General 8 04-01-2009 07:21 AM
how to reset oil life etovar 2008 Vue 3 02-23-2009 05:52 PM
04 oil life monitor reset gaurdien Vue Tech 3 11-02-2006 12:01 AM
