Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
Old 10-08-2022, 10:55 AM   #1
rickwhoo
rickwhoo is on a distinguished road
Default Speedo Off
Last night I discovered that my speedometer was off. It was reading about 4mph slower than I was going. I used google maps speed, my radar detector and a speedometer app to prove this. I need to find a way to fix this. The tires are the correct size too.
Anyone else have this issue?
rickwhoo is offline   Reply With Quote
Old 10-08-2022, 05:26 PM   #2
Default Re: Speedo Off
Not expert on Saturn Sky with few Sky owers posting here. Perhaps searching out Pontiac Solstice forums and other Sky forums may present a wealth of info and/or owners sharing issues, repairs, etc to ask.
In general and because I have service manuals for my L300, the body control module does all the electronic work the engine control module (ECM) and xmission control module (TCM in some vehicles) doesn't perform. Things like factory security, DRL, interior/exterior lighting, remote communications, instrument panel gauges/warning indicators except abs/tc and airbags (each has their own module/indicator) and gateway for all modules sending error messages to the bcm connected to the OBD II port. Without service manuals to refer to specific functions like speedometer, there may be a speed sensor in the xmission sending signals to the bcm to drive the speedo or a wheel speed sensor signal to the bcm, driving the speedo. Most Saturn instrument panel gauges are electronic, receiving signals from the bcm. It's not likely for bcm failure as there would be other major issues pointing to the bcm. And not likely to be the speedometer unless it was change/altered/modified or other mods were performed that you're aware of (or not).
Old 01-10-2023, 06:47 AM   #3
RedOne07
RedOne07 is on a distinguished road
Weefvrgrg g gtbt th t th tb
RedOne07 is offline   Reply With Quote
Old 01-10-2023, 02:28 PM   #4
rickwhoo
Say What???
94 SC2 No Speedo BOZZZ S-Series Tech 4 10-30-2008 12:30 AM
speedo maxwedge1964 Vue General 14 11-10-2005 04:52 PM
Help me fix my speedo! please! sps SOHC Miscellaneous Tech 3 11-17-2004 09:37 PM
speedo & odo daddio S-Series Tech 3 09-08-2004 09:04 AM
bad speedo sl2hippie S-Series General 6 12-29-2003 01:00 AM
