Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
Old 01-07-2022, 02:35 PM   #1
larry_chip
larry_chip is on a distinguished road
Default Reversed jumper cables now no start
Hi I mistakingly reverse the jumper cables and right after Iím not getting any clicking or turning over from the vehicle I was wondering is there a leaky main fuse that mightíve popped when reversing the cables? Thank you
larry_chip is offline   Reply With Quote
Old 01-07-2022, 07:31 PM   #2
Default Re: Reversed jumper cables now no start
Rather than guess, after finding reversed jumper cables with a no start result when cables were reconnected correctly (positive to positive, negative to negative), did you examine fuses in the engine bay and any other fuse panels inside the car?
Old 07-31-2022, 10:04 AM   #3
Trexer
Trexer is on a distinguished road
2007 ION-2 Sedan
Check fuses, not sure if it has a fusible link, but look that up and if so check that as well. Then report back.
Trexer is offline   Reply With Quote
Jumper cables on a 2002 sl2 Saturn battery.... stupid question? Nigey S-Series Tech 5 11-26-2021 09:41 AM
Reversed jumper cables! SMOKE ampecsu S-Series General 5 12-09-2018 03:02 PM
Car starts when you jump start but when you remove jumper cables it will die vikasevan S-Series Tech 13 02-17-2017 11:07 PM
Reversed Jumper Cables - 2000 Saturn SL2 Automatic dylank S-Series Tech 40 03-03-2015 06:48 PM
Jumper cables reversed, white smoke, no start, HEEEELP Magilla S-Series Tech 41 06-14-2013 08:52 PM
