#1 |
![]() ![]() ![]() Join Date: Aug 2020
I have an 08 saturn vue greenline 95K, it has what looks like a really good oil leak coming from what looks like the oil pan. My question is is it a pretty straight forward oil pan removal and rtv application and re-install? or am I goin to run into issues with the oil dipstick like previous ecotech 2.4? Any advice from anyone whose done it will be appreciated.
#2 |
You may just have an oil pan seal leaking oil. The 2.4L also may have the lower case seal to block (upper case) seal leaking oil. If the lower case seal is leaking it will be about 4" higher than the oil pan. and behind the starter.
Case reseal is a big job typically about 12-13 hours in the shop by an experienced technician. |
Bookmarks |
Oil Leak, Coolant Leak, Alternator, Compressor | Bobcat124_23456 | L-Series Tech | 4 | 03-25-2013 10:13 PM |
question about radiator stop leak helping a leak from the plastic end caps | tmoncrief | S-Series General | 6 | 09-04-2012 02:51 PM |
Colant Leak - Small leak turned into a big one | Raysp30 | S-Series Tech | 3 | 03-02-2009 07:25 PM |
Driver side leak & sunroof leak-common? | Miss Holly | S-Series Tech | 3 | 01-06-2008 02:01 AM |
evaporator core leak -- opinions on 'stop leak' products? | brenspin | S-Series Tech | 12 | 01-31-2006 12:29 AM |
