#1 |
![]() ![]() ![]() Join Date: Feb 2009
Location: Birthplace of Rust, FKA The Heart of the Rustbelt, AKA The Angry White Planet Ohth
2001 L-Series 3.0L Wagon
Found transmission fluid on the ground, thought it may had been my failure to replace the crush washer "every time" I did the transmission fluid swap, yet I see the fluid coming from what appears to be the lines connected forward left side of the transmission.
These are machined into the transmission, and have that appear to be small cannisters attached before being clamped to a rubber hose I imagine goes to the radiator. Not sure if I want to play with them from the amount of corrosion on them either. Major problem or easy fix? It's a slow leak but nevertheless. I'm not sure what the pressure is either under driving conditions yet the transmissions still appears to be full.
Angry White Planet Ohth.... The REAL "Salt Life"! |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2013
2008 AURA XE
Pretty sure you are talking about these transmission cooler lines. I had one start leaking on my Aura. Wasn't too difficult to change.
https://www.rockauto.com/en/catalog/...ler+line,10343 This video should give you a guide on how to change them. On your Vue it looks like you can just change the line that is leaking. https://www.youtube.com/watch?v=aVlaDBjTCrg
2008 Saturn Aura XE 3.5L 4 spd 2000 Saturn SL1 1.9L SOHC (Retired) |
#3 |
Thank ypou for the links & yes that's where its leaking looks like at the transmission. Looks like a 1 piece assembly connected on the flange near the block, yet the ones shown at Rock is one tube, he glossed over if that area was disassembled. His underbelly looks so clean, not the Ick we deal with up north.
I was thinking of wrapping it with a PTFE tape for the time being, how much pressure in that line?
#4 |
2008 AURA XE
The video was for a different but similar model. Parts listed for yours details two separate lines.
Not sure of the pressure but Gates rubber transmission cooler hose is rated for 250 PSI working pressure. If the line breaks while driving you'll be stuck and could potentially harm the transmission. Fix it, not worth the risk.
#5 |
In the link you had posted for Rock, I see one for FWD & another for AWD, but only one line a piece. (??)
I don't buy online, & just too much low hanging fruit on this vehicle now + the service frame is gone, not sure about the K frame. I really want to resolve the thudding issue in the rear going forward, though just going through guess fixes that don't solve it.. Was going to just run this till spring but should just dump it at this point, this vehicle develops issues faster than I can fix them. Transmission still looks like it has sufficient fluid left, not sure if it's coming out faster during driving I only have driven this on limited occasions since the thudding started 2 years back. No longer work on these especially in the cold due to arthritic issues, try to find honest mechanics! BTW how much fluid do these lines retain when removed, not the entire 5 qt displacement?
Angry White Planet Ohth.... The REAL "Salt Life"! Last edited by Bismarck318; 12-09-2020 at 03:17 PM. |
#6 |
...If I were you I would just get the ac delco trans lines and new fittings. I did mine while I had everything apart while doing a motor change. I found out under a plastic retaining clip that holds both lines ,the trans lines just disintegrated. Glad i changed out both lines, they were starting to get a bit crusty.It was just a matter of time before blowing ,With 97000 miles, good ol' ny salt, just my.02, DC
#7 |
In an ideal world, yes, hate to put another grand into it & find the K frame is gone like Mr. Buffalo told me a few years back.
Dunno if the tape will work, & lines all look seized. About a $500 job then?
#8 |
...Got my trans lines and new fittings at rock auto, shouldn't be too bad about 200 bucks for everything,if that, if i remember correctly. The ac delco lines were decent quality. Pull the little clips on the fittings with a small pick and the lines should pop out with a tug. Expect them to be crusty, there is also a spot where they are reinforced with a plastic tab where they run parallel, that is held together with a bolt. They are a bit fun to get to on the trans and radiator if you have larger hands, good luck,hope that helps, DC.
#9 |
...Send me a message with you email and i can email a pic of the front of engine which shows the lines, DC
#10 |
...I guess some pics got downloaded.
#11 | |
![]() Quote:
It's sitting in 15" of snow right now.
Bookmarks |
Leaking Transmission lines | imaddicted2u | Aura General | 2 | 04-12-2018 02:11 PM |
99 SL1 - leaking transmission cooling lines FIXED - Part numbers | theunpaidBill | S-Series Tech | 0 | 09-02-2017 04:00 PM |
Coolant leaking from lines that lead to heater core | Dukenukemx | L-Series Tech | 1 | 07-26-2011 07:00 PM |
Help! I need the diameter of a leaking metal brake fluid lines on a 98 sl1. | tocagao | S-Series Tech | 6 | 10-01-2010 09:00 PM |
Leaking coolant out of the radiator at tranny cooler lines. | almies | S-Series General | 6 | 04-05-2005 10:12 AM |
