Old 11-21-2020, 05:54 PM   #1
callitandrea
callitandrea is on a distinguished road
2008 AURA XE
Default 08 aura ect sensor or thermostat issue
My temp gauge stops working and ac won't work. However, it will start working and ac and everything works fine. The car isn't getting hot. I went to auto zone and had them put the scanner thing on it. I got back error codes p0013, p0128, p1682. There is 130000 miles on the car. How do I determine if it's the ect or the thermostat?
callitandrea is offline   Reply With Quote
Old 11-21-2020, 09:05 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: 08 aura ect sensor or thermostat issue
As a general rule P0128 is caused by a stuck open thermostat. Without a scanner that can display the ECT sensor temperature output it's guesswork. However, in your case with the gauge indication failing. I'd be inclined to inspect the wiring and connector to the ECT sensor and if it appears OK, change the ECT sensor.
I've listed information on your codes below. If you aren't having any other issues, you should clear the codes and see if they return.
P0013 SATURN - Exhaust Camshaft Position Actuator Solenoid Control Circuit
https://www.engine-codes.com/p0013_saturn.html
P0013 SATURN Possible Causes
Dirty Oil
Low engine oil level
Faulty Exhaust Camshaft Position Actuator Solenoid
Exhaust Camshaft Position Actuator Solenoid harness is open or shorted
Exhaust Camshaft Position Actuator Solenoid circuit poor electrical connection
Faulty Engine Control Module (ECM)
P0128 SATURN - Engine Coolant Temperature Below Thermostat Regulating Temperature
https://www.engine-codes.com/p0128_saturn.html
P0128 SATURN Possible Causes
Leaking or stuck open thermostat
Low engine coolant level
Insufficient warm up time
Faulty engine coolant temperature sensor
Engine coolant temperature sensor harness is open or shorted
Engine coolant temperature sensor circuit poor electrical connection
P1682 SATURN - Ignition 1 Switch Circuit 2
https://www.engine-codes.com/p1682_saturn.html
P1682 SATURN Possible Causes
Faulty ignition switch
Ignition Switch harness is open or shorted
Ignition Switch circuit poor electrical connection
08 aura ect sensor or thermostat issue callitandrea Aura General 3 01-15-2021 06:23 AM
Thermostat Issue? theviper121 S-Series Tech 42 04-13-2017 07:40 PM
Thermostat and Sensor replacement noelalberto8 Vue General 10 11-24-2014 09:20 PM
2007 Aura possible thermostat? jthigpen Aura General 2 04-19-2012 01:51 PM
THermostat issue 95c2 S-Series Tech 5 09-01-2006 08:44 AM
