Old 11-07-2020, 02:19 PM   #1
a1handy
a1handy is on a distinguished road
Default 07 Vue - Engine Dies when placed in reverse
I have an 07 Saturn Vue with a 2.2-liter engine that has 147000 miles. The engine runs great but every time I place the shifter in Reverse the idle drops and the engine finally stalls. This does not happen in drive or any other available positions. The car idles around 1200 RPM in park and drops to 1000 RPM when placed in drive. When placed in Reverse the idle drops to around 400-500 RPM and the engine stalls. I have replaced the throttle body, ECM, MAP sensor, and temperature sensor but no change. Does anyone have any suggestions?
a1handy is offline   Reply With Quote
Old 11-08-2020, 10:01 PM   #2
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Default Re: 07 Vue - Engine Dies when placed in reverse
Check all your engine grounds for a break. I had something similar to this happen on an old Grand AM I once owned. It idled fine but once placed into drive it would just die. Tracked it down when pulling on the wire harness while idling and it died, the ground wire was broken making an intermittent connection. Fixed that and it ran like a champ.
Not saying this is your issue but something to look at.
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
SL2 Engine dies!! SL2nf150 S-Series Tech 29 11-24-2013 12:58 AM
02 vue 2.2 5sp dies when brakes are pressed and when put in reverse. reinhart0901 Vue Tech 2 11-15-2013 11:15 AM
93 SL2 automatic dies going from reverse to drive quickly. Crasoum S-Series Tech 0 09-16-2008 12:38 PM
engine dies allen57 S-Series Tech 13 09-16-2007 10:54 AM
Hard kick when going into Reverse, then dies? Yokozuna S-Series Tech 13 07-16-2002 08:40 AM
