#1 |
![]() Join Date: Nov 2020
2006 VUE 3.6L
Hi All.
This is my 3rd Saturn in 20 years; that's how much I love them! This one, an 06 Vue, I've had to replace 2 02 sensors the past couple months and I still get the same error codes (for the same bank (1)), plus there's a High Voltage error code each time, too. Pretty sure it's a wiring issue, but I am no mechanic nor electrician. I've gone from 32mpg to 13mpg in just the past year. Has anyone else had this electrical problem? And how did you fix it? I suppose I could start throwing different fuses at it, but something tells me it's a wiring problem, but don't have a clue how to go about finding it. Thanks in advance! Nico H |
#2 |
![]() ![]() ![]() ![]() Join Date: Sep 2007
2000 SL2
2006 VUE 2.2L
What are the codes? Why did you mention fuses? Is this a 6 cylinder?
#3 |
2006 VUE 3.6L
Hi
The one that keeps showing up is P0138 ("Circuit High Voltage (Bank 1, Sensor 2"). The other code that kept showing up until this SECOND 02 sensor replacement was P0139. So, after replacing sensors, my three different mechanic friends say it's definitely a wiring issue. One of them did suggest changing fuses, since that'd be a quick and easy (and cheap) troubleshoot, though unlikely the culprit ![]() Nico H |
#4 |
2006 VUE 3.6L
PS Sorry, I forgot to answer that last question. It's a V6.
#5 |
Search threads about P0138/P0139 within Saturnfans. It would help to puts vehicle stats into your profile to eliminate playing twenty questions.
http://www.saturnfans.com/forums/sho...d.php?t=156020 |
#6 |
2006 VUE 3.6L
Thank you, FDryer
I've updated the stats per your suggestion. And I looked at the PDFs you linked to. My mechanics reset everything each time, but it's still a matter of electrical wiring (Tripping the O2 sensor/voltage codes), but where the actual culprit is we still don't know. Thanks again. Nico H |
Bookmarks |
TPS high voltage | RobertGary1 | S-Series Tech | 5 | 03-02-2013 04:05 PM |
High Voltage mod | papoopeepoo | S-Series Mods | 19 | 11-10-2012 10:54 AM |
What is causing high voltage to #2 O2 sensor? | wolfgang2204 | S-Series Tech | 11 | 07-16-2008 05:57 PM |
Battery voltage too high | Dale.g | S-Series Tech | 25 | 01-21-2008 04:22 PM |
PCM IAC valve voltage to high | danster | S-Series General | 14 | 10-09-2005 11:53 AM |
