Old 09-19-2020, 03:35 PM   #1
chris fowler
chris fowler is a jewel in the roughchris fowler is a jewel in the roughchris fowler is a jewel in the rough
Default Engine coolant temp sensor / A/C related?
The engine coolant temp sensor went bad and at the same time the a/c stopped blowing cold. I changed the temp sensor and the gauge indicated correct temp and the a/c started blowing cold again. Is there a relationship between the two, or are they seperate things? The temp sensor started failing intermittently and the a/c would not blow cold but when it started sensing again the a/c worked.
chris fowler is offline   Reply With Quote
Old 09-19-2020, 05:25 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Engine coolant temp sensor / A/C related?
That's normal when the temp sensor fails.
https://repairpal.com/ac-quit-workin...s-not-move-929
Where is the ECTS (Engine Coolant Temp Sensor) chad878262 2008 Vue 6 08-12-2020 05:26 PM
engine coolant temp sensor arcnsparkjohn S-Series General 3 09-17-2012 10:56 AM
Engine coolant temp sensor? sleepersatty99 S-Series Tech 8 06-06-2009 09:06 PM
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
engine coolant temp sensor skijay S-Series Tech 10 04-30-2003 10:19 PM
