#1 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2015
2007 AURA XE
Can anyone tell me the part number for an oil pressure sensor/switch for a 2007 Saturn Aura 3.5L v6? I've found conflicting information on the web -as well as different pictures, so just want to make sure I get the right part.
Also, I'm willing to spend more if it means I get a quality part that works -is this something I should only buy OEM for? Has anyone had any luck (or bad luck!) with particular brands? Thanks!
2007 Saturn Aura XE 3.5 L LZ4 V6 2002 Saturn SL2 1.9L (manual) |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2013
2008 AURA XE
According to GMpartsgiant.com the 2007 takes GM Part No.:12635992
You can go to the site and enter your VIN to double check. I changed the sender on my 2008 XE in July 2015. I used a sender from NAPA, # OP6887, never had a problem with it. The sender housing and threads are aluminum so don't over tighten it and put a little on on the o-ring. I did a write up on changing it, just added a video. http://www.saturnfans.com/forums/sho...18#post2349918
2008 Saturn Aura XE 3.5L 4 spd 2000 Saturn SL1 1.9L SOHC (Retired) |
#3 |
2008 AURA XE
Oops...put a little oil on the o-ring.
#4 |
2007 AURA XE
Just want to say a big thank you to you imaddicted2u, very helpful!
Bookmarks |
Part number for a CMP sensor to fix P0010? | johnfrei4 | 2008 Vue | 2 | 10-12-2015 10:08 AM |
Sensor part number? | StarLady | S-Series General | 10 | 03-20-2013 11:56 PM |
OE part number for gen1 temperature gauge sender | PlasticCarsRock | S-Series Tech | 9 | 03-16-2012 01:09 AM |
What is the Part Number for the Air Intake Sensor on a 1995 SW2 ?" | SalemCat | S-Series Tech | 4 | 09-26-2011 09:37 PM |
Universal O2 sensor part number?? | Cat Fuzz | S-Series Tech | 3 | 01-08-2008 02:49 PM |
