Old 08-16-2020, 05:37 PM   #1
41 BigDog
41 BigDog is on a distinguished road
Default bad growl & vibration.(front differential ? )
pulled the driveshaft stopped the right wheel from turning and when the left starts to turn the noise starts. Oh by the way, I have the front end off the ground. Any ideas. 2006 Vue AWD 3.5 V-6
41 BigDog is offline   Reply With Quote
Old 08-16-2020, 07:24 PM   #2
waiter21
2003 VUE 2.2L
Default Re: bad growl & vibration.(front differential ? )
Front bearings, very common problem.
Old 08-17-2020, 08:01 AM   #3
41 BigDog
replaced both brgs. removed drive shaft, with front end off ground and right wheel held from spinning, makes real bad noise and vibration. is it the diff or trans???
Old 08-17-2020, 09:51 AM   #4
waiter21
2003 VUE 2.2L
Maybe, but......
If you take the wheel off then turn it. I assume its on the drivers side only.
Look carefully at the sheet metal mud /gravel shield thats on the inside of the wheel/hub assembly. I've had the metal tab bend in a little and it makes a lot of noise when it touches the disk.
Old 08-18-2020, 04:58 PM   #5
Vue6
Vue6's Avatar
2006 VUE Red Line
...Does it click while turning left or right? Possibly cv shaft going, just my .02, DC.
Front End 'Growl" When Turning Right -- Mount? kewlpop S-Series Tech 6 12-01-2017 02:30 PM
Growl left front in 2003 AWD V6 VUE. buyavue Vue Tech 5 11-12-2012 10:30 PM
front end growl Thundercat Vue Tech 19 07-28-2011 09:06 AM
front end growl tkrzywonos S-Series Tech 4 12-14-2007 12:06 PM
91 SL2 - Low growl in front crenzi S-Series General 3 07-06-2005 08:29 AM
