Old 08-14-2020, 11:33 AM   #1
Jefferyod
Jefferyod is on a distinguished road
Default 2007 Saturn Aura A/C issues
I have replaced the blower motor and the Blower motor control Module. Now I dont have power at the fuses labeled HVAC CTRL IGN and HVAC BLOWER. All other fuses and relays are good any thoughts on where to start looking.
Jefferyod is offline   Reply With Quote
Old 08-14-2020, 12:03 PM   #2
Default Re: 2007 Saturn Aura A/C issues
Some circuits requires ignition ON for powering up specific areas. Electronics replaced mechanical switches for smaller cabin footprints, switchology, by miniaturization and using low voltage signals so electronics can switch things on off.
Did you turn on ignition before measuring for fuse power?
Old 08-14-2020, 12:08 PM   #3
Jefferyod
Yes car was turned on and then tested again while started.
Old 08-14-2020, 02:31 PM   #4
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Check fuses #19 #20 #25 under hood.
Old 08-14-2020, 02:59 PM   #5
In addition to the above, are there any fuse panels inside the cabin?
Old 08-14-2020, 03:07 PM   #6
imaddicted2u
2008 AURA XE
The fuses the OP mentioned are in the BCM fuse panel inside the car.
Old 08-14-2020, 03:08 PM   #7
My bad. I thought those fuses were in the engine bay. I wish I had access to Alldata or Mitchell........
Old 08-14-2020, 03:16 PM   #8
imaddicted2u
2008 AURA XE
Here is a link to the owners manual. The 3 fuse boxes are detailed starting at page 392.
https://my.gm.com/content/dam/gmowne...ura_owners.pdf
Old 08-17-2020, 03:25 PM   #9
SRGW
1997 SL1
Post Re: 2007 Saturn Aura A/C issues
Does this help?
1995 SL1 236,300 2005>2018
1997 SL1 84,300 2014>????
CHECK YOUR OIL!!
Old 08-17-2020, 04:43 PM   #10
SRGW
1997 SL1
AC power 1
Old 08-17-2020, 04:54 PM   #11
imaddicted2u
2008 AURA XE
SRGW, I was going to post those diagrams but I don't think they are correct. The owners manual shows that only the fan high speed relay is in the instrument panel/BCM fuse block.
2007 Aura XR TCS issues/rattling xlevix10 Aura General 3 04-27-2019 08:54 PM
Radio Issues on 2007 Saturn Aura XR cbery92 Aura General 9 05-22-2015 03:46 AM
2007 Aura XR issues ??? alfisalive Aura General 8 05-15-2014 04:04 AM
2007 Saturn Aura XR Sunshade Issues? zam290 Aura General 5 07-26-2013 11:34 PM
Issues with my brand new 2007 Aura XR.... cisco0623 Aura General 10 12-15-2007 01:49 AM
