Old 08-06-2020, 09:56 AM   #1
blacknbluevue
blacknbluevue is on a distinguished road
blacknbluevue's Avatar
2007 VUE 2.2L
Default Clutch problem
2007 cue 160k miles
I've driven manuals for 35 years and never experienced a problem like this. In the span of 30 minutes and 20 miles my clutch stopped working. Gradually the pedal went further to the floor and now goes all the way. The driver's floor has a lot of liquid on it, presumably from the clutch. There is no other fluid evidence anywhere. No drips on the linkage or anything, both inside and out. Is this a slave cylinder problem, throwout bearing?
Thanks
1991 SL1 5 sp 120K mi SOLD
2004 Ion 2 L61 5 sp 155K mi SOLD
2005 VUE L61 5 sp 181K mi LOST IN TS JOAQUIN 10/2015
2007 VUE L61 5 sp 155K mi
blacknbluevue is offline   Reply With Quote
Old 08-06-2020, 11:22 AM   #2
waiter21
2003 VUE 2.2L
Default Re: Clutch problem
Sounds like master cylinder.
If fluid is on floor is DOT3 brake fluid, then its probably coming from the clutch master cylinder, leaking past the actuator shaft (the shaft that the pedal presses)
Fairly easy fix, replace the entire master cylinder assembly. I'd recommend bleeding it before installing it, it will make your life a lot easier.
Something like this:
https://www.amazon.com/Evan-Fischer-...dp/B07BWGRSKY/
If you do a good job of bleeding the master cylinder, you won't need to re-bleed it when you install it on the car.
If the pedal is hard, DO NOT FORCE IT.
Here is a link to how to bleed - read the entire thing, but pay attention to Bleeding The Master Cylinder.
http://www.saturnfans.com/forums/sho...d.php?t=222577
Clutch problem remetal S-Series Tech 2 12-26-2011 04:59 PM
02 has a clutch problem, need help! jlsworld Vue General 7 08-28-2009 06:42 PM
clutch problem Sony Mods and Performance 4 07-09-2005 07:11 PM
'98 SC2 with coolant problem +unrelated clutch problem Kpendrgn S-Series Tech 11 07-12-2003 10:02 PM
VUE Clutch Problem? jmatero Vue Tech 2 05-07-2003 06:43 PM
