Old 06-24-2020, 03:28 PM   #1
currentvueowner
currentvueowner is on a distinguished road
Default 2006 Vue 2.2L Door Lock Issue
Driver's lock switch being a pain. If you leave it alone for a while sometimes it works, and then if you try a couple more times it seems like it's losing power and works less and less. The other doors are the same, but not as much as the driver's door. The passenger lock switch works as advertised. Doors do unlock when put into park. No fob. (that's another question - I didn't get a fob with the car; do all Vue's have a fob?)
I had assumed the switch was going, so I replaced it. No joy.
I swapped out the 3 door lock relays under the dash with my other 2006 Vue. Nada.
I checked the 10A fuse under the hood and the 20A under the dash. Nope.
Is there something else I can check, or is the driver's door lock actuator dying?
2006 Vue 3.5
2006 Vue 2.2
Former 2001 L300
currentvueowner is offline   Reply With Quote
2006 Vue door lock actuator mkez1 Vue Tech 0 07-05-2017 09:00 PM
2006 Vue AWD V6 rear door lock Mike229 Vue Tech 6 06-06-2016 03:53 PM
2006 Vue door lock buttons andywin58@gmail Vue Tech 1 01-10-2014 07:52 PM
2006 FWD broken rear door lock help barnkat Vue Tech 1 10-14-2011 11:18 AM
2006 Vue Door lock switches not working mindfreak87 Vue Tech 5 09-13-2011 04:50 PM
