Old 06-02-2020, 06:35 PM   #1
GTRik
GTRik is on a distinguished road
Default Replaced the Fishing Pole Antenna
Hi ALL, GTRik from Calgary, Alberta, Canada.
I put a request in to the Tech forum, about information swapping out the stock antenna to a GM "stubby" antenna. I was able to quickly figure out the wiring and placement, after a couple trips to the auto wreckers. About $20 in total, including two antennas.
Just thought I would share the visual on the general forum (via the link below). This was a fairly east mod to do, and is an interesting alternative to the "Shark Fin Capper" mod!
http://www.saturnfans.com/forums/att...4&d=1591135871
By the way, is there any way to post the same picture in two forums?
GTRik is offline   Reply With Quote
Old 08-17-2020, 04:14 AM   #2
nickson
nickson is on a distinguished road
Default Re: Replaced the Fishing Pole Antenna
Like it! It looks better than the stock antenna.
nickson is offline   Reply With Quote
Old 09-22-2020, 09:11 AM   #3
twbixler
twbixler is on a distinguished road
I'd like to replace my antenna. Will any later model GM antenna work or does it need specific specs?
twbixler is offline   Reply With Quote
Old 09-26-2020, 03:05 PM   #4
FreedomSoftware
FreedomSoftware will become famous soon enough
2008 Astra XR
There's a shark fin antenna i posted a while back. Do a quick search and you will find my post about it this year. You have to email the company but they can make one and they paint it for $90 if you want to pony up...
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-Thule Roof Rack (and wind fairing)
-1.25" Lowered
-Windows Tint all around
-JVC Head unit
-Dual 12" Subs
FreedomSoftware is offline   Reply With Quote
Old 09-26-2020, 11:33 PM   #5
JFS
JFS has a spectacular aura aboutJFS has a spectacular aura aboutJFS has a spectacular aura about
JFS's Avatar
2008 Astra XR
If you are satisfied with the base and just want a shorter extension, then most M6 fittings should work. This antenna base appears shared with the Saturn Outlook and GM sister SUV's. That part is shown below and can be found for less than $10 if you look a while on Amazon and EBay:
https://www.ebay.com/p/1111212127?ii...8aAh1CEALw_wcB
If the base gasket is wasted, replacements can be found for about the same price on the British Ebay.co.uk. My repair using a similar part is here:
http://www.saturnfans.com/forums/sho...d.php?t=230459
Best of luck.
JFS is online now   Reply With Quote
Old 09-28-2020, 03:15 PM   #6
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Thanks for the link. The base on mine looks like it's spent, well, 12 years in the sun. Might think about replacing it.
Sadly I'm starting to see some somewhat significant clearcoat bubbling on my rear bumper cover. Looking to get a quote from a nearby shop to claybar the cover and respray clearcoat; the base still looks ok.
Former: 2005 L300, 2007 VUE Green Line
Current: 2008 Astra XE
tackepj is offline   Reply With Quote
Old 09-28-2020, 03:44 PM   #7
AstraFasta
I put some silicone caulking around the base of my antenna to avoid the hassle. Seems to last about a year.
If you are going to spray the bumpers, note that the front bumper just under the headlights seems to have very thin paint. Check that out. If you don't want to spend much money, you might try plastidip spray DIY. Not sure how it would come out.
Wheel into a Pole Ruger141 Ion Tech 10 04-13-2019 11:12 PM
a 2004 Saturn Vue that hit a utility pole. tominsky Vue General 22 06-03-2006 03:34 PM
FS: Fishing Rod and Reel Combo - Auction goldenSL1 Classifieds 0 03-12-2004 03:29 AM
Saturn on the POLE KevSC1 General Saturn Discussion 9 09-19-2003 11:09 PM
