Old 03-08-2020, 03:04 PM   #1
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default VVT Solenoid issues.
Hello, haven't been here in the Aura section for a while. in 2013 I traded my 2008 Aura XE in and bought a 2011 Camaro SS. Still have the Camaro, but recently picked up a 2007 Aura XR with the 3.6L V6. Unfortunately some issues have popped up and I'm thinking it may be related to the VVT solenoids.
Purchased the car a few weeks ago from the original owner. Has a little over 200k miles. Inside and out is in immaculate condition. Almost looks brand new. Carfax shows a huge list of maintenance records since the car was new, but nothing specific to whats been done.
Symptoms are:
-Slightly rough idle at times. Nothing drastic, but noticeable. RPM fluctuates a couple hundred RPM with a slight vibration.
-Engine occasionally bogs under load and driving up hill. Also if I give it increased throttle at highway speeds to pass. At lower speeds and flat ground, acceleration is ok. If I continue giving it throttle, sometimes it will stumble a bit then accelerate. Other times I have to briefly let back on the throttle and them get it more and it goes.
-No codes
Thank you.......
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-08-2020, 09:03 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: VVT Solenoid issues.
Tough to diagnose without it throwing any codes.
Here is some info on VVT symptoms.
https://www.yourmechanic.com/article...g-vvt-solenoid
Old 03-13-2020, 12:11 AM   #3
bunginherent
bunginherent is on a distinguished road
Symptoms are:
-No codes
Thank you.......
This is an absolute help to a new car owner like me, thanks for this!
bunginherent is offline   Reply With Quote
Old 03-14-2020, 02:58 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Turn out my issue wasn't the VVT solenoids, it was the plugs and coils. Confirmed by using my OBDII app and monitoring cylinder misfires during my commute to and from work.
Found the plugs needed replacing and while I was at it, replaced the coils too.
Mike
-1991 Turbo SL2.
Old 03-14-2020, 06:12 PM   #5
imaddicted2u
2008 AURA XE
Good news, everyone likes a happy ending.
2001 Saturn L300 Temp Gauge Issues + Blower Issues Help? Glaciata L-Series Tech 1 02-04-2018 09:27 PM
Canister vent solenoid/Vent control solenoid. hulkbam Vue Tech 4 01-10-2012 03:53 PM
Shocking discovery - EGR solenoid instead of purge solenoid StarLady S-Series Tech 11 07-29-2010 08:08 PM
Checking the Solenoid (and other electrical issues) Ross22 S-Series Tech 3 06-05-2010 08:16 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
