Old 03-07-2020, 10:54 AM   #1
helpfulbook
helpfulbook is on a distinguished road
Default Dead Battery and Locked out
Guys I am locked out with a dead battery. My key for some reason does not unlock the door.
2008 Saturn Astra XR
Does anybody have any suggestions?
Thank you for your help!!
helpfulbook is offline   Reply With Quote
Old 03-07-2020, 11:51 AM   #2
AstraFasta
Default Re: Dead Battery and Locked out
That's strange. I suppose you tried both keys. And inserted the keys 180*.
I suppose a locksmith might be able to help. OnStar can unlock a lot of GM cars but if the battery is dead that might be difficult.
DIY option
https://www.youtube.com/watch?v=gxEzhvtcJB8
Old 03-07-2020, 11:58 AM   #3
helpfulbook
Yeah I was thinking the same thing. I think onstar needs a live battery.
Thank you for the idea!
Old 03-07-2020, 06:06 PM   #4
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
You should try to spray some lube into the lock cylinders. If you don't use the key in the door regularly they may be seized up.
You could also try to pop the hood through the grill. That way your could get a boost or a charger on it.
I did this when the hood release cable broke on my Aura, not sure it will work on Astra.
Old 03-08-2020, 08:54 AM   #5
helpfulbook
I only have 1 key. The other key was used when I had a remote starter installed.
The key turns but it does not unlock the door.
I turn the key clockwise 180 degrees.
I read somewhere that the manual key lock is also electrically activated.
I dont know if that is true or not.
I'll try some lube in the lock.
Ang try getting in through the grill.
Thanks for the help guys!
Old 03-08-2020, 12:22 PM   #6
imaddicted2u
2008 AURA XE
This video is for a Vauxhall Vectra C but it looks like the same hood mechanism. At 3:24 it shows the hood release cable. Hopefully you can get something hooked around it so you can pull it to pop the hood or maybe you can come up with something to push it from the passenger side. You may be able to get to it from underneath. Hopefully the video will give you some ideas.
https://www.youtube.com/watch?v=t6h3p3V9UfY
Old 03-08-2020, 02:48 PM   #7
imaddicted2u
2008 AURA XE
Another trick to get a jump or charge on the battery would be to jack up, safely support the car and gain access to the starter.
Connect the charger - lead to the chassis or engine block and the + to the heavy red wire on the starter solenoid (it connects directly to the battery). Plug in the charger and give it a few minutes to charge a bit, hopefully then the door will open.
You could do the same with a boost pack or battery.
Old 03-25-2020, 06:01 AM   #8
albatross
albatross is on a distinguished road
Can you open the trunk with a key? You can go through the trunk!
albatross is offline   Reply With Quote
Dead Battery? PanVet Astra General 10 05-15-2011 09:16 PM
dead battery??? Gottofried S-Series General 5 11-29-2005 09:34 AM
Dead Battery!!!Please Help magimoo S-Series General 20 10-25-2005 12:52 AM
Radio Locked After Removing Battery KMEDARIWSW S-Series Tech 2 01-30-2005 03:39 PM
Battery goes dead on LS1 after tow behind R.V. sattech L-Series Tech 0 03-28-2000 10:47 PM
