Old 03-02-2020, 04:59 PM   #1
eusjma
eusjma is on a distinguished road
Default Installed Tail Lamp Assembly with LED
I have a 2007 Saturn Aura XR.
The Right Tail Lamp Assembly got broken.
I purchased a used one that apparently came off a 2008 Saturn Aura.
The 2007 had a normal back up bulb. The 2008 assembly has an LED back up bulb.
So now the right side as LED back up bulb, the left side has a "normal" bulb.
Should I have any concern? Do I need some sort of equalizer for the LED light?
So far it all works without issue.
If I decide to replace the left side with a matching assembly would that be a problem (again wondering about an equalizer)?
Thanks
eusjma is offline   Reply With Quote
Old 03-02-2020, 10:04 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Installed Tail Lamp Assembly with LED
Sounds like whoever owned the car that taillight came out of replaced the incandescent bulb with an LED bulb. You can just pick up a set of matching bulbs at the autoparts store so they both match. I believe they're 921's.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-03-2020, 01:41 AM   #3
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Yep, the original backup lamps are #921 incandescent bulbs.
Old 03-06-2020, 01:22 PM   #4
eusjma
oh ok
That makes sense. I thought maybe Saturn changed the design between 2007 and 2008
Thanks for the feedback!
Old 05-14-2020, 05:03 AM   #5
ogada
ogada is on a distinguished road
thankyou somuch for the info
ogada is offline   Reply With Quote
Removing Headlight lamp assembly Russet L-Series Tech 12 10-31-2014 04:45 PM
Rear Right Lamp Assembly out YayForBeers Astra Tech 3 11-29-2013 08:08 PM
Finding replacement tail lamp assembly? vaska Astra General 6 04-17-2012 11:07 AM
Help Fog Lamp Assembly Replacement 2000sc2 S-Series Tech 0 08-26-2011 08:45 PM
tail lamp/bulbs Melissa_M S-Series General 3 11-07-2009 09:07 PM
