Old 02-12-2020, 09:40 PM   #1
Aeryn
Aeryn is on a distinguished road
Default Mechanic recommendation for '03 Vue in Orange County CA
I have an oil leak of unknown origin, small but slowly getting worse. Not in a position to DIY.
I have been taking my Vue to a GM dealership for regular maintenance but they've tried my last nerve.
Anyone have a recommendation in Orange County?
Add to Aeryn's Reputation
Rate the quality of this post and help Aeryn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Aeryn is offline   Reply With Quote
Old 02-16-2020, 10:08 AM   #2
Cavell
Default Re: Mechanic recommendation for '03 Vue in Orange County CA
V6 vue?
Add to Cavell's Reputation
Old 02-18-2020, 01:46 PM   #3
Aeryn
Yep, V6.
Old 02-22-2020, 01:57 PM   #4
burnt orange
burnt orange is on a distinguished road
You need some references from friends or some such source...Here in kansaas the vue dealership went over to a gm/buick dealer..But their a ways away. I just take it into a shop thats been around awhile...They do my ford pickup too..
Add to burnt orange's Reputation
Rate the quality of this post and help burnt orange reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burnt orange is offline   Reply With Quote
Old 02-22-2020, 02:42 PM   #5
Cavell
Motor is made by opel of Germany. Any foreign shop could change the valve cover gaskets. Though I bet only 2% of mechanics have ever worked on one. Remove intake plenum, change gaskets. Use good silicone gaskets. Not cheap $20 “rubber” Chinese ones. I saw a vue at junkyard with radiator/front end gone. The motor was COVERED in oil. Ugh.
Old 03-02-2020, 11:29 PM   #6
Aeryn
Argh! Notifications have been spotty on this thread.
Sorry for ignoring you for a week, and thanks for the info! I'm not at the "covered in oil" point but I do feel that's the direction I'm heading. :-(
Old 03-03-2020, 04:58 PM   #7
Most GM and repair shops know their way around most vehicles but there are the exceptions that don't have a clue knowing the gas cap from coolant cap...... The trick is knowing which ones to stay away from. If your patience is worn out from your local GM dealer, perhaps it's time to try another dealer. Good repair shops are known by word of mouth and speaking to the shop or mechanic may give a clue about trusting repairs to a new place. Maybe a shop (non dealer) will put your Vue on a lift for an initial inspection and give it a quick look then invite you to see what they see. Every repair shop has insurance regulations prohibiting customers into service bays especially under a vehicle lifted above the ground so the exceptions depends on each shop to bend the rules of they want customers to see what they see. Good shops will invite the vehicle owner to look at their vehicle on a lift if they feel comfortable with safety in mind.
Old 03-21-2020, 10:26 AM   #8
Cavell
Plastic valve covers may have something to do with oil leaks? I know the front exhaust manifold is a perfect flat surface where the oil drips onto and causes smoke burning issues. I worry more about a 17yr old timing belt. Records of service?
Old 03-25-2020, 10:29 PM   #9
Aeryn
Original owner Timing belt is 5 years old.
I was going to try another dealership at the end of month, but then the world jumped off a cliff. It's getting less than 10 miles a week right now so I'm just sitting tight.
Old 04-05-2020, 12:11 PM   #10
Cavell
Bought a v6 3.0 vue that had been mistimed. I pulled heads to repair bent valves and noticed 2 of the 3 timing belt rollers were new. So, I put in a new 3rd one. After I got done I looked in box of parts seller gave me and it had new cam seals. Agh, that I did not install. Don’t recall if valve covers had new gaskets. I sold it pretty quick.
Orange County CA Saturn Mechanic Needed TVCCS L-Series General 4 08-07-2017 03:04 PM
Saturn Service in South Orange County, CA OldTechGuy L-Series General 1 01-27-2014 04:20 AM
Good Saturn mechanic in San Diego North County? Yober Vue General 0 06-30-2013 01:33 AM
Picked up our Sky Red Line (Orange County, CA Owner) Tenchi Masaki Sky Red Line 12 10-28-2007 06:14 PM
Orange County, Ca: Know of a good indy Saturn Mechanic? meesr Community Center 0 12-27-2006 12:52 AM
