Old 02-06-2020, 01:06 PM   #1
Tricha122
Tricha122 is on a distinguished road
Default Key stuck in ACC due to shifter micro level failure
My car has been having issues with the key getting stuck in ACC after parking. I converged on the problem being the micro level switch in the shifter assembly. This was no longer completing the circuit. I spent some time with the console open using a screwdriver every time to get the key out. When I lost my mind doing that I took it to the dealership. Twice. And both times they ghosted me after saying I needed a new shifter assembly. I got the impression that they couldn’t get this part anymore.
So I took matters into my own hands and grabbed a piece of wire and shorted the circuit with solder. Now I can take my key out / turn the car off anytime! Even on the highway!
This obviously doesn’t make me feel very good, but at least it works. Is it possible to find the micro level and install it myself? It looks like a very simple part to swap out. Where could I find the exact model?
2009 Saturn vue hybrid living in Toronto.
Thanks for any help!
Add to Tricha122's Reputation
Rate the quality of this post and help Tricha122 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tricha122 is offline   Reply With Quote
Old 02-06-2020, 06:08 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Key stuck in ACC due to shifter micro level failure
The lever on the installed micro switch looks to be custom but you should be able to use this one, you'll have to create the bend on the end of the lever and cut off any excess off the lever.
https://www.amazon.com/Twidec-Straig...1026550&sr=8-1
Here is a video that demonstrates the problem:
https://www.youtube.com/watch?v=QExRpOxUGak
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Key stuck in ignition and shifter stuck in park also won’t crank twigstick Ion Tech 2 03-20-2019 10:01 PM
05 Ion Level 3 won't crank/automatic shifter locked in park vjhall Ion Tech 13 01-29-2017 09:40 PM
Not your average shifter bushing failure. anmasher S-Series Tech 5 02-12-2015 01:27 AM
my flow direction control is stuck on chest level silvervu Vue General 2 10-31-2009 12:32 PM
shifter stuck can get into 1 or 2 jlp7534 S-Series Tech 3 03-29-2006 06:20 PM
