Old 01-30-2020, 08:58 AM   #1
carbuff91
carbuff91 is on a distinguished road
Question P2176 Engine Code
Hello all,
First time here and I'm hoping someone can help me out with this issue. I had some errors related to to high an idle coming up on the car and cleaned the TB a few times and cleared the codes and the problem went away for a week or so.
I decided to replace the TB because I had seen the P2176 code come up before and bought a unit from AutoZone (AC Delco). So, I replaced it this past weekend, installed a new gasket with it and did the whole relearn process (I disconnected the battery for a half hour too).
Well a few days later I get the check engine light and service engine soon light again with the P2176 code. Would it be the ECM at this point or is there something I don't know about these cars that someone could shed some light.
Thanks all!
Add to carbuff91's Reputation
Rate the quality of this post and help carbuff91 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carbuff91 is offline   Reply With Quote
Old 01-30-2020, 10:05 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: P2176 Engine Code
What year and engine?
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-30-2020, 10:41 AM   #3
carbuff91
Sorry, 2003 AWD with the 3.0 automatic
Old 01-30-2020, 07:15 PM   #4
imaddicted2u
2008 AURA XE
This may help or maybe you've read it already.
https://www.justanswer.com/saturn/30...vue-tried.html
Old 01-31-2020, 08:21 AM   #5
imaddicted2u
2008 AURA XE
Some more info on the P2176 code.
https://www.engine-codes.com/p2176_chevrolet.html
Old 01-31-2020, 07:34 PM   #6
carbuff91, what's your idea of a relearn procedure?
Old 02-04-2020, 11:37 PM   #7
dr_phillgood
dr_phillgood is on a distinguished road
2002 VUE 3.0L
I spent years chasing this one on my 2002 AWD. The TSB about the wiring harness was the final fix. I eventually had to replace that wiring harness. Changing the throttle body doesn't resolve it for long. Once, I asked my mechanic to check the harness connections and clean it up. That worked for 3 years, but the 2176 and 700 codes came back. Replacing the whole harness was the most permanent fix and the car runs much better
Add to dr_phillgood's Reputation
Rate the quality of this post and help dr_phillgood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dr_phillgood is offline   Reply With Quote
p2176 Throttle not learned pocomenomosso Vue General 12 12-27-2019 09:12 AM
P2176 code after fueling. pjrobbins Vue Tech 1 10-09-2018 09:14 PM
Limp mode with code P2176 Casey223 Vue Tech 17 11-29-2017 01:58 PM
New View - P2176 and P0700 codes Raysp30 Vue Tech 5 09-18-2011 04:52 PM
P2176 and P1779 Z13VUE Vue Tech 6 04-26-2008 11:46 AM
