Old 01-17-2020, 03:21 PM   #1
greghotz
greghotz is on a distinguished road
Default 2007 2.2 Vue bad head gasket/crack block Eng replacment?
I have a 2007 Vue with a 2.2 I4, It is the vehicle I use to tow behind my motor home. I have the dreaded "Chocolate Milkshake" brown foam in the oil, It has been noisy on startup recently but quieted down after a few minutes, Also the oil pressure light stayed on for about 6 seconds after it started running. I know that usually means a blown head gasket or possible cracked block. I don't see oil in the water, just the foam in the oil pan. What other cars use this engine? It may be easier to replace the entire engine with a low mileage used one. I have about 150,000 on the original one. I have heard the engine is used in many other GM products. Can you tell me which ones?
Thanks!
Add to greghotz's Reputation
Rate the quality of this post and help greghotz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greghotz is offline   Reply With Quote
Old 01-17-2020, 10:45 PM   #2
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
Default Re: 2007 2.2 Vue bad head gasket/crack block Eng replacment?
Check your oil level. If it was accidentally overfilled, it can get whipped up by the crank, and look kind of like what you're describing.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
1999 Saturn SL2 - Rislone Block Seal (Head Gasket) Protomartyr S-Series General 51 05-22-2018 01:43 PM
Head gasket? Cracked head / block? Paranoia? reverser S-Series Tech 2 04-16-2014 11:11 PM
Crack in block!!!!!!! PSDFan S-Series General 21 10-16-2013 01:18 PM
Head Gasket or Engine Replacment Robert53 Ion Tech 0 06-27-2011 02:41 PM
Crack in Cyclinder Block jonhoyle General Saturn Discussion 1 10-01-2000 11:23 PM
