Old 01-16-2020, 04:39 PM   #1
NACMaverick
NACMaverick is on a distinguished road
Default 08 Vue 3.6L massive oil leak
I appreciate any and all help before I start this project! The 3.6L vue has developed a pretty healthy oil leak that looks as though it's on the transmission side of the engine, somewhere in the top half. I have oil pooling in one of the recesses on top of the transmission bell housing, and as well on top of the block between the cylinder heads.
My guess is that it's a valve cover gasket leaking, running on top of the block, and on turns, runs out and collects on the bell housing. But that is just wild speculation. I dont think this is the rear main seal, nor head gaskets as it has no other symptoms besides the oil leak.
I included a picture, the circle is the oil pool on the bell housing and the arrow points to area of the block between the cylinder heads and below the intake manifold.
NACMaverick is offline   Reply With Quote
Old 01-16-2020, 04:56 PM   #2
NACMaverick
Default Re: 08 Vue 3.6L massive oil leak
It seems I cannot post an image as of yet due to my limited post history. So there goes that.
Old 01-18-2020, 12:01 AM   #3
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
The PCV office in the right (rear) valve cover is likely plugged. this may crank case pressure to push oil back wards out the fresh air side of the pcv system and / or any seal or gasket see:
TSB #PI0746E: Malfunction Indicator Lamp (MIL) On, Poor Acceleration, Throttle Body Freezing, Multiple DTCs Set, Ice Deposits and/or Oil Deposits Present in Air Inlet Duct - (Apr 15, 2014)
Old 01-18-2020, 08:02 AM   #4
The only reason images can't be posted is image file size, often too large and unacceptable when larger than 150 kilobytes. Virtually every digital camera and cellphone creates multiple megabyte images far too large to include as attachments. The solution is simple. Use an image handler like Windows Paint or similar software to resize images to less than a megabyte and in jpeg format for acceptance as attachments.
Sudden massive transmission leak terminal89 S-Series Tech 30 04-12-2018 01:23 PM
1997 SL2 - massive oil leak cbrguy S-Series Tech 10 04-17-2013 05:11 PM
massive oil leak jstephens L-Series Tech 33 11-02-2012 12:15 AM
Massive oil leak mechanic380 L-Series Tech 3 02-29-2012 08:44 PM
Massive oil leak on startup thefishin6 L-Series Tech 7 11-06-2006 01:10 PM
