Old 12-30-2019, 12:27 PM   #1
Cherokee_Indian
Cherokee_Indian is on a distinguished road
Default 2007 Satun Aura XR
Hello,
I need some assistance with the Head Lights on my 2007 Saturn Aura XR. Last year the head light on driver side was not working. At that time, my AC also needed some work. When I took it to the garage to fix both, the mechanic said the light started working and they worked only on the AC and nothing on the head light.
Few weeks back both head lights are not working. When I tested, the high beam works but ,not the low beam.
I am wondering if the fuse for the head lights are gone. Where is the fuse for head lights located?
Any other thoughts or suggestions?
Thanks!
Add to Cherokee_Indian's Reputation
Rate the quality of this post and help Cherokee_Indian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cherokee_Indian is offline   Reply With Quote
Old 12-30-2019, 05:04 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: 2007 Satun Aura XR
Originally Posted by Cherokee_Indian View Post
Hello,
Thanks!
The fuse box under the hood contains the headlight fuses
7 Left Headlamp Low-Beam
9 Right Headlamp Low-Beam
11 Left Headlamp High-Beam
12 Right Headlamp High-Beam
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-30-2019, 05:15 PM   #3
imaddicted2u
2008 AURA XE
Relays:
35 High Beam Headlamp
38 Low-Beam Headlamp
Old 12-30-2019, 05:26 PM   #4
imaddicted2u
2008 AURA XE
If fuses look good, swap around relays 35 and 38. If the low beams start working and the high beams stop working, replace relay #35 with a new one.
Old 12-30-2019, 08:14 PM   #5
Cherokee_Indian
Thank you! From the pic for Engine Compartment Fuse Block you sent, I can see Fuse 11 and 12. But not Fuse 7 and 9.
Where is Fuse 7 and 9 located?
Thanks!!
Old 12-30-2019, 08:16 PM   #6
Cherokee_Indian
Relays:
Thank you! Are the Relays (35 and 38) located in Rear Compartment Fuse Block in the trunk?
Thanks!!
Old 12-30-2019, 08:31 PM   #7
imaddicted2u
2008 AURA XE
They are all in the engine compartment fuse box. I marked them in red in the pic.
Old 12-31-2019, 02:23 PM   #8
Cherokee_Indian
Thank you!
Old 12-31-2019, 02:53 PM   #9
imaddicted2u
2008 AURA XE
Circuit diagram from G6, should be close enough for Aura
2007 aura 3.5l Broke_saturn Aura General 1 07-23-2017 06:03 PM
2007 Aura xe Mike 373 Aura General 11 10-28-2010 08:42 PM
2007 Aura XR vs 2007 Passat 3.6 VR6 Seasoned Aura General 5 12-09-2006 04:12 PM
2007 Aura XR vs 2007 2.0T passat sedan, which to buy? fantarain Aura General 43 11-26-2006 12:39 PM
2007 SKY or AURA? brianottis S-Series General 9 04-06-2005 07:39 PM
