Old 12-27-2019, 11:04 AM   #1
Kwillis
Kwillis is on a distinguished road
2008 Astra XR
Wrench 08 Astra oil cooler replacement
My oil cooler needs to be replaced in my Astra, but im not sure all that i need for parts. Can anyone help me with a parts list for this job so i know im buying all the right parts. Im going to be trying to do this work myself.
Add to Kwillis's Reputation
Rate the quality of this post and help Kwillis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kwillis is offline   Reply With Quote
Old 12-27-2019, 12:32 PM   #2
AstraFasta
Default Re: 08 Astra oil cooler replacement
There are a lot of videos on youtube for the z18xer engine oil cooler replacement (astra, sonic, cruze, vectra, zafria etc.).
Also note the oil pressure sensor switch can cause of oil leaks on some Astra engines, although I don't that is such a big issue on the z18xer. Look at it in anycase.
I had oil leaks related to the valve cover gasket and PCV flapper. But in the process, researched the Oil Cooler issue. Here are some of the links I saved:
https://www.youtube.com/watch?v=oPUJZWVa1p4
https://www.astraownersnetwork.co.uk...929/?id=326929
https://www.vectra-c.com/forum/showt...ctra-C-1-8-VVT
https://www.vauxhallownersnetwork.co...cement.565601/
Add to AstraFasta's Reputation
Rate the quality of this post and help AstraFasta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Radiator Fan? Transmission cooler? 08 Astra H CruzzieQ Astra General 2 05-31-2018 09:00 PM
Oil cooler and T-stat replacement krt L-Series Tech 2 12-29-2013 11:05 PM
Oil Cooler Replacement AdubSaturnVue Vue Tech 1 03-20-2012 04:31 PM
Oil cooler replacement & DRL relay Partymmudasti Vue Tech 0 08-05-2008 04:21 PM
Help with 03 vue v6 oil cooler replacement Chulo Wear Vue Tech 1 02-17-2008 05:18 PM
