Old 12-15-2019, 11:31 AM   #1
Durvelle27
Durvelle27 is on a distinguished road
Default 2005 Vue 2.2 5 Spd Transmission issues
Alright guys i really need some help as I'm really stumped at this point. My slave cylinder recently went out so i went ahead and replaced it. I replaced the slave cylinder, clutch,clutch pressure plate, and the entire master cylinder assembly. I bled the system using tbe method i found on this here forum and the clutch pedal feels great just about better than before. Alright on to tbe issue, i get the car down out the air to test drive and as I'm riding down the street in 2nd gear i started hearing a grinding nose and all of sudden the car stopped going as if it was in neutral. Giving it gas does nothing. Alright so we some help i push it back to my shop get it back in the air and remove both front wheels. Start the car and put it in gear to see if i could still hear the sound but nothing and weirdly both sides are spinning even if i press the accelerator. Test all gears and they shift fine and clutch still feels good. Finally i try reverse and i could clearly hear the grinding noise from before.
Do you guys know what the issue could be as I'm stumped.
Durvelle27 is offline   Reply With Quote
Old 12-15-2019, 11:36 AM   #2
Durvelle27
Default Re: 2005 Vue 2.2 5 Spd Transmission issues
To be exact my vehicle is a 2005 Saturn Vue with a 2.2L ECOtech engine and a 5 Speed Manual F23 transmission. Truck has about 287,000 Miles on it. I did the work because the slave cylinder had went out.
Old 12-15-2019, 04:02 PM   #3
In general, all differentials are alike in operation. On the ground both drive wheels provide traction. In turns, the outside wheel turns in a larger radius so it turns faster than the inside wheel turning in a smaller radius. The differential allows this for left and right turns. The weakness of diffs is on slippery surfaces. The wheel spinning on gravel, sand, ice, snow, wet leaves, water, gets all the power while the good wheel that has traction (sticks to the ground) and should turn, doesn't. Every differential has this weakness. When both drive wheels are off the ground, nothing is preventing each wheel from turning.
With drive wheels off the ground, engine idling, in gear, hold one wheel. You're duplicating the same conditions as if on slick surfaces with one wheel having traction (the wheel you're holding from spinning). All power should turn the opposite drive wheel. Repeat holding the other wheel and expect the opposite wheel to spin. If two people lightly grab each wheel, both will turn as if on dry ground. Be aware of performing this test with drive wheels off the ground and in gear. Use all precautions without distractions and any safety to prevent the car from traveling on its own. Have three people if needed; one sitting in the driver's seat in case anything goes wrong with the other two for wheel holding to test differential action. Use 1st and reverse gear. Running rpm up isn't necessary.
Old 12-15-2019, 11:11 PM   #4
Durvelle27
Ok so i don't know what i did but i removed the wheels shook the driver cv axel checked tranny fluid reinstalled wheels and now she is running fine with no issues.
2004 vti saturn transmission awd be swapped with a transmission in a 2005 fasttrack Vue Tech 1 12-16-2016 04:47 PM
2005 Vue V6 AC issues 2005vuev6 Vue General 10 07-01-2016 11:07 AM
PCM Update 2005 2006 2007 Vue 3.5 - Transmission Issues Resolved turbo1point4 Vue Tech 4 09-24-2013 08:29 PM
2005 Vue sputtering issues Derbking7 Vue Tech 23 04-10-2013 12:30 PM
2005 VUE Manual Transmission Issues 2NDSOUT Vue Tech 14 11-26-2007 11:01 AM
