Old 09-16-2003, 02:49 PM   #1
sp33doe
sp33doe is on a distinguished road
Default Iac Valve Cleaning??
to all techs
how do you clean the IAC VALVE without taking out the TB
any bolts to remove?
car is an LS1 2000 2.2 5 SPEED
thanx for any help
Add to sp33doe's Reputation
Rate the quality of this post and help sp33doe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sp33doe is offline
Old 09-16-2003, 04:55 PM   #2
TedL
TedL is on a distinguished road
Default
I could tell you, but since I'm not a tech, it seems you don't want to hear from me.
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 09-16-2003, 05:44 PM   #3
Dach
Dach is on a distinguished road
Default
He didn't say certified or even Saturn tech. Certainly you are a tech in some field or another.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline
Old 09-16-2003, 06:09 PM   #4
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
Without taking out the tb... unbolt the iac and clean the pintle and the port with some carb cleaner (or other suitable solvent).
Without taking out the valve, spray a bunch of carb cleaner into the iac hole (in front of the throttle plate, in the throttle body) with the engine running. gets it almost as clean...
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 09-16-2003, 07:09 PM   #5
sp33doe
Default
ty saturn Eh
to the guy who first responded (tedl) its up to you if you gonna give some input or not.
let me just rephrase that " to all people" lol
ty again
sp33doe is offline
Old 09-16-2003, 09:18 PM   #6
Dr. Bob
Dr. Bob is on a distinguished road
Default
I'm not a tech... but I play one on TV...
Add to Dr. Bob's Reputation
Rate the quality of this post and help Dr. Bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr. Bob is offline
Old 09-17-2003, 06:14 AM   #7
Dach
Default
Well I'm not one either...but I did stay at a Holiday Inn last night.
Dach is offline
Old 09-17-2003, 06:40 AM   #8
TedL
Default
Sorry, I was just poking a little fun. My experience ends with '96 DOHC engines. I don't know what's in your vehicle.
Some points that may still apply...............
For me on the earlier DOHC: You can do it without removing the TB, but getting it off is such a PITA that I'd much rather burn a few bucks on the new gasket and take off two easy nuts/bolts, than squeeze my hands between the engine & firewall, drop the screws a few times, lose one, etc.
Also, on the earlier DOHCs, the manual recommends replacing the IAC o-ring, which goes for $9.
Now, the access issues may not apply to your vehicle/engine, but a broader question does: If the IAC needs cleaning, why not give the TB that it's part of a good cleaning? And if you're doing that, my personal view, despite Gumout's reassurances, is that I'd rather not run half a can of carb cleaner, and the crud it dislodges, through my engine, around my plugs, past my O2 sensors and into my converter. I know it's not going to do them any good!
TedL is offline
Old 09-17-2003, 09:45 AM   #9
sp33doe
Default
ty tedl
might take the whole tb out and do a good cleaning on it
sp33doe
sp33doe is offline
Old 09-25-2003, 06:52 PM   #10
sp33doe
Default torx
what about the size of the two bolts torx anybody knows the size?
ty
sp33doe is offline
Old 09-25-2003, 06:53 PM   #11
sp33doe
Default
i mean to say the 2 bolts on IAC VALVE,,,,, SIZE?
sp33doe is offline
Old 09-25-2003, 08:47 PM   #12
TedL
Default
As I said in my PM response, for my vehicles, both the IAC and the TPS use two T-20 bolts. Later engines????
Easiest approach is to buy a set of torx sockets for $10 or so. I've used almost all of the nine or ten sizes I have in the past couple of years.
Sears has a cheap set.
Companion 8 pc. Star Bit Set
8 pc. bit set includes 1/4 in. dr. T15, T20, T25; 3/8 in. dr. size T30, T40, T45, T50. Clip rail included. $7.99
Or
Companion Folding Torx Key Set
Folding Torx key set includes T9, T10, T15, T20, T25, T27, T30 and T40. $4.99
TedL is offline
Old 09-26-2003, 03:03 PM   #13
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
I take my throttle body off to clean it all the time. It really only take a few mins, and as there is no fluid using that gasket I see no reason why you can't reuse it. I picked up a new gasket and have had the TB off 3 times now. It is still in fine shape. Also with the TB off, you can clean the thick black gunk off the back of the throttle plate.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 09-27-2003, 10:30 AM   #14
Luke
Luke's Avatar
Default
Fm Applefool
Good alert, thank you applefool
Add to Luke's Reputation
Luke is offline
Old 09-27-2003, 09:18 PM   #15
FrozenPilot
FrozenPilot's Avatar
Default
I got a chance to look at the FSM when I was down in Fargo this week. For cleaning the throttle body it recommends removing it so you can clean the entired thing, meaning easier access to the IAC and backside of the throttle butterfly. It recommends a new gasket, but I believe wolfman said 9 times out of 10 you can reuse the old gasket. Very easy job, much easier to clean the IAC this way. BTW, not sure exactly what size bolt for the IAC, but it is one of the more common Torx sizes.
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline
Old 09-27-2003, 10:08 PM   #16
Applefool
Applefool's Avatar
2006 ION Red Line
Default
The IAC and TPS use T-20 torx bits, and I believe 2 10mm bolts are all it takes to remove the TB.
Old 09-28-2003, 07:12 PM   #17
sp33doe
Default
thanx guys for all ur response
i do appreciate it
5 speed 2000 ls1 2.2
sp33doe is offline
Old 09-28-2003, 07:16 PM   #18
sp33doe
Default
oops,,,, applefool what is a TPS?
2000 LS1 2.2
sp33doe is offline
Old 09-28-2003, 07:20 PM   #19
Applefool
Applefool's Avatar
2006 ION Red Line
Default
Throttle Position Sensor
Old 09-28-2003, 07:25 PM   #20
sp33doe
Default
ok ty
sp33doe is offline
Cleaning the IAC/TB peterseb S-Series General 1 11-09-2005 03:53 PM
cleaning iac valve SimPlyxTriPPiN S-Series Tech 8 11-30-2004 11:38 AM
cleaning TB, IAC Zigmund555 Miscellaneous Tech 5 07-01-2003 06:32 PM
Cleaning throttle body/IAC advice please auxmike S-Series Tech 6 01-26-2003 09:46 AM
Cleaning the Idle Air Control (IAC) valve Heartbeat - '95 SL2 Miscellaneous Tech 5 05-29-2001 04:29 AM
