Old 05-18-2004, 07:37 AM   #21
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default
Hey Spazie,
Be careful when you go for the wire connector...there is a plastic piece that covers the wires which is attached to the sensor piece. I pulled it off and thought I had broke the plastic cover, but it snaps right back on.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
2NDSOUT is offline
Old 05-22-2004, 10:05 PM   #22
freakerz
freakerz is on a distinguished road
freakerz's Avatar
Default
I bought meters, you know for oil, temp and volt.. you say "DO NOT PANIC", well I PANIC and I returned the product to Canadian Tire LOLOLOL.. I didn't read your post in time I guess =( .. oh well, 40$ for something else.. like paint..
Add to freakerz's Reputation
Rate the quality of this post and help freakerz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freakerz is offline
Old 05-25-2004, 04:22 AM   #23
wolfman
wolfman's Avatar
Default
Just read this after a few weeks. Important note: Put the cap BACK ON the resevoir tank TIGHTLY after removing it to relieve any pressure on a STONE COLD engine. The cap is a ONE WAY VALVE. If you still get a huge amount of coolant loss out the tiny ECTS port when the sensor is removed, either:
1. The engine was indeed NOT stone cold, or:
2. The resevoir tank cap seal or cap one way vent valve in it is bad.
You should not get a huge amount of coolant loss if the directions are followed to the letter and the system is intact (sealed) and the cap is good and securely tightened, after being initially removed to vent any residual pressure.
Add to wolfman's Reputation
wolfman is offline
Old 05-30-2004, 03:18 AM   #24
cozkramer
cozkramer is on a distinguished road
Default
I'd just like to say Hi to everyone.. The house has a '96 SC2 that I get to work on for some reason. I mainly deal in old pre '72 cars so this aluminum and plastic thing is new.. Bear with me plz.. I've read over this forum for a few days and will say, WOW! What a great buncha guys!
So, onto the reply.. I cannot stress enough Wolfman's "Don't Overtighten" statement.. There's a photo to follow.. I'd like to add, Do NOT use a 1/2" Socket Wrench to install this! Stick with a 3/8 or 1/4. It may have only cost me an extra $17 for another part, but the time and agravation, not to mention scare factor was not worth it!
The black twisty thing is a #4 Fluted Screw Extractor.
Add to cozkramer's Reputation
Rate the quality of this post and help cozkramer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cozkramer is offline
Old 05-31-2004, 01:44 AM   #25
sierrap615
sierrap615's Avatar
Default Re: Re: Re: Replaced ECTS
Originally posted by ZoomEquipd
Do you just wash the engine off w/ some water from a hose to get it clean? My dad said to take it to the car wash and use the pressure washer on it.. i'm worried that the pressure would cause damage??
don't use a pressure washer, that would be very bad. on his old cars from the 60s or 70s, this may have worked. but on today's cars the damage would two fold. first there are countless sensors and modules and solinoids and blahblahblah, much more then any older car. second, and more importently, all the wiring connection have weather seals, which work great normally. but with a lot of pressure, not only will the weather seals fail, when the pressure returns to normal, water becomes trapped inside the seals and connectiors, and its not that it may corrode, its that it WILL corrode.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 05-31-2004, 08:46 AM   #26
Luke
Luke's Avatar
Default
Fm Sierrap
Point, very, very well made...
Add to Luke's Reputation
Luke is offline
Old 06-14-2004, 10:08 AM   #27
JayNYC
JayNYC is on a distinguished road
Default
Wolfman, you are amazing! I changed this part a few eeks ago and my gas mileage has gone from 175 miles per tank to 310!!! This part paid for itself in under a week!
Thanks!
-Jason
Add to JayNYC's Reputation
Rate the quality of this post and help JayNYC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JayNYC is offline
Old 06-18-2004, 09:28 AM   #28
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default
I'm not getting too great gas mileage. I'm replacing my radiator so I'm going to replace this too. Right now I think I'm getting around 240-260 miles a tank. I don't really know because my odometer is broken.
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 06-19-2004, 12:54 AM   #29
sierrap615
sierrap615's Avatar
Default
you may want to throw in another $10 and change the thermostat too.
Old 07-08-2004, 07:02 AM   #30
freedominco
freedominco is on a distinguished road
freedominco's Avatar
Default
followed these instructions and it took ten minutes
Add to freedominco's Reputation
Rate the quality of this post and help freedominco reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freedominco is offline
Old 07-09-2004, 07:13 AM   #31
Kentai
Kentai is on a distinguished road
Default
Should I have to change my ECTS on my '01 SL1 after 25k miles (I part-time deliver pizza in it, miles rack up fast)? Would it make a difference in my mpg? Any improvement would be fantastic considering the current gas prices...
Add to Kentai's Reputation
Rate the quality of this post and help Kentai reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kentai is offline
Old 07-09-2004, 08:12 AM   #32
amazinghl
Default
Would help if you tell us what you're getting now.
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 07-10-2004, 06:37 PM   #33
Kentai
Default
Pretty consistent around 240 on a full tank that I run nearly down to E. What I was curious about is whether or not this new all-brass sensor comes stock on my car already or not, since it's a '01? And don't tell me to go look, that would require... uh... effort.
Kentai is offline
Old 07-14-2004, 12:44 PM   #34
freakerz
freakerz's Avatar
Default
Saturn 93 SL1 ECTS: 13mm DEEP WELL
freakerz is offline
Old 07-19-2004, 08:51 AM   #35
geeminator
geeminator is on a distinguished road
Default
I guess this is another good thing to replace after I replaced my valve cover gasket and spark plugs/wires the other day...The car has stumbling idle after it warms up unless it's the computer "relearning"...Or is there some other issue I need to address?...no codes being thrown and spark plug gap is at .040 Car is a 97SL2.
Add to geeminator's Reputation
Rate the quality of this post and help geeminator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geeminator is offline
Old 07-31-2004, 03:27 PM   #36
zippy_LiL_sL1
zippy_LiL_sL1 is on a distinguished road
Default
Yup, just looked at the old ects about ten minutes ago. It was cracked all the way around. 10 minute successfull swap out.. following wolfman's instructions. I am noticing a considerably cooler running engine. Maybe gas mileage will improve as well?
Add to zippy_LiL_sL1's Reputation
Rate the quality of this post and help zippy_LiL_sL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zippy_LiL_sL1 is offline
Old 08-01-2004, 11:37 PM   #37
sps SOHC
sps SOHC's Avatar
Default
my engine temp never goes above quarter now w/ the new ECTS and the radiator. I would think that it should...
sps SOHC is offline
Old 08-16-2004, 09:39 AM   #38
Razorbak
Razorbak's Avatar
Default Re: Changing the ECTS (Engine Coolant Temp Sensor)
Originally posted by wolfman
Using the 13mm deep well socket, tighten the new ECTS into the engine by turning it clockwise. Keep the socket as straight as possible over the sensor to avoid damaging it. Keep turning until you feel it "bottom" in the hole but DO NOT OVERTIGHTEN IT!
FYI, the torque spec is 8 Nm (71 in-lbs).
Add to Razorbak's Reputation
Razorbak is offline
Old 09-07-2004, 12:59 PM   #39
canaryrx8
canaryrx8 is on a distinguished road
Default
can someone post a pic of the location for a 2000 sl2? either my search criteria was off or ...? but I could not locate one. Thanks!
Add to canaryrx8's Reputation
Rate the quality of this post and help canaryrx8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
canaryrx8 is offline
Old 09-07-2004, 01:13 PM   #40
Razorbak
Razorbak's Avatar
Default
The forum search database isn't working very well right now. (Forum owner is testing out new features.) Check the pictures in the following thread, and then look under your car's hood in the same location as the lower sensor that the wrench is turning...
http://www.saturnfans.com/forums/sho...threadid=37884
Razorbak is offline
Engine coolant temp sensor? sleepersatty99 S-Series Tech 8 06-06-2009 08:06 PM
Changing the Engine Temperature Coolant Sensor saturnpuppy Vue Tech 4 04-26-2008 09:15 PM
Changing the ECTS Coolant Temp Sensor (with pictures) auxmike How-To Library 43 10-02-2005 01:51 AM
Here's my famous cracked Coolant Temp Sensor Scan {ECTS} auxmike S-Series Tech 36 01-30-2005 01:17 PM
engine coolant temp sensor skijay S-Series Tech 10 04-30-2003 09:19 PM
