Old 12-07-2019, 04:30 PM   #1
Cavell
Default Auto fluid level?
Did a drain fill on my 3.0 vue. Aisin trans. 4.5 was came out. Did it on my equinox which has same trans. About 4 qts came out. I added 4.5 and had slight drips from fill port? Sold it. So today I did it on my replacement nox and 3.5 qts came out. So, I added 4qts and no drips. Put maybe 1/4 qt more in and stopped. Don’t feel like running motor and checking level. Been told I should get 4.5 qts but I think nox has new radiator so I am 90% sure they never topped off trans as fill port is buried. Is 4.5 a good fill amount?
Add to Cavell's Reputation
Old 12-15-2019, 03:56 PM   #2
Cavell
Default Re: Auto fluid level?
Drove it everyday this week. Seems a bit smoother. Iíll probably have it till spring. Might do a 2nd drain in a few months. Or maybe not
Old 12-17-2019, 11:27 PM   #3
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
That transmission should have a dipstick behind the engine mount.
Add to bern's Reputation
Old 12-18-2019, 12:39 PM   #4
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Originally Posted by Cavell View Post
Did a drain fill on my 3.0 vue. Aisin trans. 4.5 was came out. Did it on my equinox which has same trans. About 4 qts came out. I added 4.5 and had slight drips from fill port? Sold it. So today I did it on my replacement nox and 3.5 qts came out. So, I added 4qts and no drips. Put maybe 1/4 qt more in and stopped. Donít feel like running motor and checking level. Been told I should get 4.5 qts but I think nox has new radiator so I am 90% sure they never topped off trans as fill port is buried. Is 4.5 a good fill amount?
Yes, I think so. Regardless, you should definitely check the dipstick before and after. It's easy to access if you remove the front transmission mount. Removing the mount is fairly easy and doesn't require supporting the engine/trans.
2007 Ion 2 Quad Coupe 5-speed manual 182K miles
2007 Chevy Equinox LT 194K miles
2018 Chrysler Pacifica Touring L 41K miles
Add to ruley73's Reputation
Old 12-21-2019, 11:08 AM   #5
Cavell
Dipstick would not come out. I removed mount and delicately tried to wiggle the yellow Assy out. Used several small screwdrivers to slowly pry the dipstick out. And the part that goes into trans snapped off. Dang it. I assume it will do no damage. Little chunk of plastic. Jeez. Put a little lube on o-ring and it slides in nice now. Of course.
Cold auto transmission fluid level? isoOctane S-Series Tech 12 03-14-2019 07:58 PM
Checking the Auto Trans fluid level Millhouse L-Series Tech 3 05-10-2009 01:16 AM
04 VUE AWD RDM Fluid Level ericb Vue Tech 2 06-05-2008 10:21 PM
Checking auto trans fluid level. j79phan S-Series General 1 05-23-2005 02:27 PM
SL93 Auto Trans Problems and Fluid Level ym42 Miscellaneous Tech 6 10-20-2004 07:34 PM
