Old 08-22-2003, 01:57 AM   #1
DualCamCoupe
DualCamCoupe is on a distinguished road
DualCamCoupe's Avatar
Information Jacking Up an SC2
How is the best way to jack up a 2000 SC2 in order to put it on jack stands?
Add to DualCamCoupe's Reputation
Rate the quality of this post and help DualCamCoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DualCamCoupe is offline
Old 08-22-2003, 02:53 AM   #2
wolfman
wolfman's Avatar
Default
Use a FLOOR JACK placed under the space frame rail just behind where the factory jack would go if you were changing a flat on the road. CHECK OFTEN while jacking to ensure things are staying stable and level. Place the jackstand just forward of where the floor jacks "pad" is and after you are SURE the jackstand is level and LOCKED, lower the floor jack SLOWLY until all the weight is on the jackstand. Do this ONLY on a FIRM (concrete or asphalt with a piece of plywood under the jackstand) LEVEL surface! ( On either front side just forward and toward the middle of the car from where the OEM jack's little "slot" is, you will see a spot where the space frame rails "meet" at a sort of triangle. My preferred spot for a jackstand's pad to be when supporting the FRONT end of the car.)
Add to wolfman's Reputation
wolfman is offline
Old 08-22-2003, 06:54 PM   #3
DualCamCoupe
Default
So each side should be jacked up seperately?
Old 08-22-2003, 07:10 PM   #4
wolfman
wolfman's Avatar
Default
You can do it either way. Most folks don't have two floor jacks. Doing one side at a time tends to make things more stable as you go..
wolfman is offline
Old 09-02-2003, 01:14 AM   #5
DualCamCoupe
Default
I know this sounds stupid, but I'm having trouble figuring out where the factory jack is supposed to go. I have looked through the owners manual as well as a Chiltons manual and a Haynes manual.
Old 09-02-2003, 03:23 AM   #6
wolfman
wolfman's Avatar
Default
Try the "Owners manual" in the "Trouble on the road" section or the instruction sheet on the spare tire cover...both have decent illustrations.
wolfman is offline
jacking points 97sl2DOHCaut1.9 S-Series General 8 07-17-2008 09:18 PM
who is jacking my oil? plastic torpedo S-Series Tech 40 11-09-2007 08:51 AM
Jacking up an SL1 erick295 S-Series Tech 24 11-02-2005 12:06 PM
jacking points patcal S-Series General 6 05-25-2005 08:06 AM
jacking the rear of a 94 sc2 "safe"? Mr Bill S-Series General 3 07-04-2004 08:26 AM
