Old 11-19-2019, 05:07 PM   #1
thekonn
thekonn is on a distinguished road
Default High mileage transfer case 75-140 vs 75-90
Hi, i have a 2003 Saturn Vue AWD with 270,000+ miles. I read that it recommended that transfer case require oil use 75-90. But since i have a high mileage car, should i use 75-140.
Thank you
Add to thekonn's Reputation
Rate the quality of this post and help thekonn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thekonn is offline   Reply With Quote
Old 11-20-2019, 03:43 PM   #2
ScotSHO
ScotSHO is on a distinguished road
Default Re: High mileage transfer case 75-140 vs 75-90
Thank you
I would not use thicker gear oil, as it will cut into your MPGs and wheel HP. I would simply recommend a good synthetic gear oil at the 75w-90 weight.
Add to ScotSHO's Reputation
Rate the quality of this post and help ScotSHO reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ScotSHO is offline   Reply With Quote
Transfer case fluid newbievueowner Vue Tech 20 10-05-2011 05:10 PM
Changing the Transfer Case and Power Transfer Unit Fluid myoldsaturn Vue Tech 0 07-16-2011 10:55 PM
transfer case id welderkev Vue Tech 1 12-06-2010 01:21 PM
07 AWD 3.5L Transfer Case Fluid cjhsa Vue Tech 1 05-24-2010 12:31 PM
transfer case fluid? NathanD Vue General 6 05-20-2010 10:18 AM
