Old 11-15-2019, 09:30 PM   #1
BrakeTheBreaks
BrakeTheBreaks is on a distinguished road
Default 4cyl ISS part number?
So I'm having the usual knocking from the ISS, but I can only find the part #25979679 which (although some websites say will fit my 2009 XE) is listed as fitting V6 models with the hydraulic steering. Mine is a 4cyl which I believe means electronic steering. Not sure if that distinction matters here. Please advise.
BrakeTheBreaks is offline   Reply With Quote
Old 11-16-2019, 04:17 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: 4cyl ISS part number?
If the U-joints are still good. Try this, Get some spray motor cycle chain lube. I think the stuff I used was Castrol and it had graphite in it but I don't think it matters. Extend the steering column fully. Spray the extended steering shaft then push the wheel in and out. Spray some more until it's good and wet and drawn into the shaft. I used to disconnect the upper joint and work grease into it but that would last about 6 months. I only sprayed the shaft with motorcycle chain lube once.
As far as the part goes, the Hydraulic steering version has a male and female end while the electric steering version has two female ends.
Here are a couple of buying options:
https://www.rockauto.com/en/catalog/...ng+shaft,11373
or
https://www.gmpartsgiant.com/parts/g...)&Location=pd:,
Need part number or name for this part - 2002 Saturn SL1 nxne75 S-Series General 2 10-14-2017 12:15 AM
Name this part and part number (2007 Ion-2) Swat ss Ion Tech 4 04-04-2014 11:15 PM
flex pipe exhaust part or part number? blaisedaddy Astra General 5 10-18-2012 07:14 AM
Help with part number PLEASE!! JTav8r L-Series Tech 0 05-11-2011 10:03 PM
2007 Ion: Looking for a Part Number (and maybe the part) fosgate3 Ion Tech 2 06-05-2007 09:03 PM
