Old 11-15-2019, 01:22 PM   #1
Cheesesteak
Cheesesteak has a spectacular aura aboutCheesesteak has a spectacular aura aboutCheesesteak has a spectacular aura about
2004 VUE 3.5L
Default Transmission is Kaput (probably) Thoughts?
Just happened. Was pulling out of pkg lot and turning right onto street. Loud clunk noise and car would barely move forward. Got it to shoulder. Now on it's way to a transmission specialist (AAA certified). Guess what I'm wanting to know is ...
Is a 2004 Vue (only 88k miles) fully-optioned, decent-looking and otherwise in OK condition worth having major/expensive repair in your opinions?
Any chance it's not a total replace/rebuild situation based on something similar that happened to you? (Not looking to get ripped off)
I've owned it for 3 yrs and - while I wouldn't consider it a great car - I like the size of it. With the Honda engine I expected a fairly long time before trading or putting it out to pasture. Thanks.
Add to Cheesesteak's Reputation
Rate the quality of this post and help Cheesesteak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheesesteak is offline   Reply With Quote
Old 11-15-2019, 02:51 PM   #2
Default Re: Transmission is Kaput (probably) Thoughts?
Just guessing. Automatics have been reliable ever since they replaced manual xmissions requiring learning the art of shifting gears while disconnecting the clutch. Electronically controlled automatics brought even more gears, making them more complex yet for the most part reliable. Yes, they fail but not in great numbers to be concerned about. I'm likely to lean on the possibility of a broken half shaft. When front wheel drive replaced rear wheel drive, the one weakness is when one of the half shafts break - the entire xmission is decoupled with zero forward or reverse to the other driveshaft as a consequence of the differential xmission. Yearly state inspections or diy periodic inspections can reveal when driveshafts show signs of failure. The large rubber boot contains grease used to keep the drive joints lubricated as steering and suspension forces angular movement thru ball bearing joints. A catastrophic driveshaft failure usually bursts this rubber boot while grease is thrown all over the area, marking driveshaft failure. If you're lucky, this is a driveshaft failure with replacement costing much less than xmission replacement or rebuild.
Old 11-15-2019, 07:32 PM   #3
Cheesesteak
2004 VUE 3.5L
Turns out it is NOT transmission failure. As the prior person mentioned, it involves the front axle (needs replacing) and the rubber boots on the driveshaft. I would describe it better but once I heard it would only cost me about $850 to fix I must've zoned out a little! Might have it back by Monday!
Old 11-15-2019, 09:08 PM   #4
Here's a typical driveshaft. Two are used, right and left side.
99 SW2, door lock switch kaput kailuamike S-Series Tech 7 02-14-2014 01:21 AM
A/C go kaput? SC2SkyVue Vue Tech 6 10-12-2009 09:11 PM
Ball-joint KAPUT??? ym42 S-Series Tech 5 05-30-2009 01:47 AM
Motor Fan KAPUT Perchjerker Miscellaneous Tech 10 07-08-2004 07:40 PM
92 SC kaput/finito/totalled :( ammotrooper S-Series General 5 09-19-2001 07:36 AM
