Old 11-06-2019, 10:22 PM   #1
travisp412
travisp412 is on a distinguished road
Default Code P0315
Hi Guys,
So after having several misfire codes, changing out coils/spark plugs, my father and I changed the ECM and the car ran find for a bit. However, it then threw a P0315 (Crankshaft Position System Variation) code. Looking this up, I saw the system needs to be relearned. Is this right? Or is something else the issue.
Any help would be greatly appreciated as we are trying to get this car running smoothly again.
2007 Aura XR with about 230k KMs.
Thanks for looking.
Add to travisp412's Reputation
Rate the quality of this post and help travisp412 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travisp412 is offline   Reply With Quote
Old 11-06-2019, 11:15 PM   #2
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
imaddicted2u's Avatar
2008 AURA XE
Default Re: Code P0315
Originally Posted by travisp412 View Post
Hi Guys,
Thanks for looking.
I believe it needs to be relearned after an ECM change. I changed the Crankshaft Position sensor on mine and didn't relearn it, had no issues. The function is part of misfire detection program.
It is usually relearned using a scantool but at the time I was looking around for relearn procedures, I found this link that details a manual method. I can't say if it works though, never tried it. Probably best to get it done with a scantool though.
http://www.totalcardiagnostics.com/s...-scannerreader
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-06-2019, 11:47 PM   #3
imaddicted2u
2008 AURA XE
This seems to be the procedure when using a scantool.
Old 11-06-2019, 11:53 PM   #4
imaddicted2u
2008 AURA XE
Here is another one:
Might be for another Saturn model but might work.
Might be too late though if it has been driven.
But it's free to try...lol
"If replacing PCM with a replacement PCM, procedure will be prompted automatically. Allow engine to idle until SERVICE light flashes. Hold engine speed between 3000-4000 RPM until light goes off after about 10-20 seconds."
http://www.obd2.com/support/reprog/d...turn-crank.pdf
Help w/ p0315 , p0010 p0013 p0114 p0449 Faisal Aura General 1 12-08-2015 06:26 AM
P0315 and CHNG OIL ryan_ion Ion Tech 4 02-26-2015 05:24 PM
F/S Actron cp9580 code connect scanner/ code reader ShawnV S-Series General 0 06-13-2013 05:25 PM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 10:26 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
