Old 11-03-2019, 09:52 PM   #1
Belly58
Belly58 is on a distinguished road
Default 2007 Saturn Vue battery and service vehicle soon lights on
Have a 2007 Saturn Vue with the 3.5 by. Son was driving it the other day and it died in the middle of a 4 lane road. I tried to jump start it but no luck. The battery tested under 5 volts. Bought a new battery and it started right up. Now the battery and service vehicle soon lights are on. I used a digital meter and it only reads 12v when running so it's not charging. I took the ground off from the negative that went to the wheel well and cleaned it good. Warning lights are still on. I see another ground wire that looks like it goes to the starter under the radiator hoses and the alternator looks like it's on the other side under the air box. Any suggestions on how to get to or remove the alternator or starter. Any other suggestions on things to try other than alternator? thanks
Add to Belly58's Reputation
Rate the quality of this post and help Belly58 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Belly58 is offline   Reply With Quote
Old 11-04-2019, 01:00 AM   #2
Default Re: 2007 Saturn Vue battery and service vehicle soon lights on
The battery light remaining on is pointing to the alternator. All 12v vehicles have two voltages, battery@12.5v/engine off and alternator (engine running) output@14.5v. Alternator output varies between 13v-15v with 14.5 as average. Power connections; battery positive cable to fuse boxes and starter, battery negative cable to chassis stud nearby and chassis stud to engine block. Another power feed from the starter to alternator side terminal powers the alternator. This wire is the fusible link between battery and alternator via starter connection.
With engine off, you can measure the fusible link wire in two places, at the starter terminal with the battery cable and fusible link wire and at the alternator side terminal. Both ends of the fusible link wire should measure 12.5v. Verifying battery voltage at the alternator terminal verifies the fusible link is intact or blown. Intact, the alternator failed.
The service engine soon light may be false error codes due to the Vue running on battery power when the alternator failed. Voltage dropping below a certain value, around 10v, scares electronics. Some specs states electronics may operate as low as 9vdc before odd symptoms related to low voltages suddenly creates error codes. Battery power is mainly needed to power the starter. Once the engine runs, the alternator begins outputting all the power the vehicle needs while recharging the battery. Your Vue is running on battery power on due to faulty wiring, connections or faulty alternator.
02 SC2 service, oil, & battery lights flashing! DrDan S-Series Tech 21 05-18-2017 08:06 AM
2003 Saturn Ion Service vehicle light Snagglepuss Ion General 23 11-13-2015 12:51 PM
2007 Saturn Aura XR 3.6L will not start (not battery) Bad Movie Lover Aura General 8 03-04-2013 03:51 PM
2003 saturn ion service vehicle light rchiarito Ion General 3 06-11-2008 12:31 AM
2001 Sc1. Service wrench & security lights on after battery replaced. bowler484 S-Series Tech 8 10-10-2006 08:54 PM
